Subject: making my first morph target poser 6 prob
256 opened this issue on Jun 29, 2006 · 3 posts
256 posted Thu, 29 June 2006 at 1:49 PM
newby trying to make a morph target for james high rez.
the help says
Select the body part/prop’s properties in the Properties palette, then select  "Spawn
Morph Target." A dialog appears asking you to name your new target.
I select the head then look at properties.  I see "Load morph target" but no "spawn morph target."
how to i make my own new morph target. like the help is trying to help me do.?
thank
i want just a new blank that i can then modify with poser morph tools.
Miss Nancy posted Thu, 29 June 2006 at 1:55 PM
see geep's morph tutorial (a current thread on this page)
spedler posted Thu, 29 June 2006 at 2:39 PM
Spawn morph target is not located in the properties palette, it's in the main menu bar (Object menu -> Spawn morph target).
You can't do it the way you imply though. You need to create your morph first, using the magnet for example, then spawn a target. If you do it the way you suggest, you'll just get a morph that won't do anything.
Steve
