Fulvio opened this issue on Jul 12, 2006 · 1 posts
Fulvio posted Wed, 12 July 2006 at 5:45 AM
Hi, first I would to thank all of you for sharing your scripts and your knowledge. I would ask if it would be possible to limit the action of smoother script to a selectable morph channel; I am using smoother to "clean" and smooth the action of jiggle scripts; jiggle can change only one morph at each run: it would be nice the have the same for smoother, otherwise it would smooth all the actor's parameters.
Many thanks in advance.
Fulvio
P.S.
I tried to use newjiggle.py dated 02/17/05 but I wasn't able to select the morph on which apply the script. What I'm doing wrong? Thanks again!
