Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Quote - I'm pretty new to Poser, and I'm trying to figure out how to take the parameter values of a morphed figure (say, Vickie 3.0) and apply them to clothing conformed to her (say, her morphing catsuit.) I would have thought that there would be an easy way, particularly since they share the same morphs.
In this particular case (because the to items have the same morphs) you can select V3's Body, then do Edit menu | Copy (or Ctrl-C), select the catsuit's Body and do Edit | Paste (or Ctrl-V) to transfer the morph settings.
This method will work (to varying degrees) with other items, but relies on the morphs existing in the other item and having the same name.
If the clothing has matching morphs, and they are set up as a Full Body Morph with EXACTLY the same name they should run automatically in most all cases.
Just make sure the figure was the first thing opened in the scene (no little man).
If they don't have the same name in the clothing you can either edit the CR2 (use a global replace) or make a new Full Body Morph with the right name.
