Subject: Those japanese underwear: how to make the morphs work?
simontemplar opened this issue on Jul 15, 2006 · 8 posts
simontemplar posted Sat, 15 July 2006 at 5:01 PM
http://camelot.renderosity.com/freestuff.ez?Form.Contrib=kousuke&Topsectionid=0 no matter what I do the morphs on these don't do anything? I tried to mail the author but had no response so far All suggestions welcome.
Acadia posted Sat, 15 July 2006 at 5:14 PM
Quote - http://camelot.renderosity.com/freestuff.ez?Form.Contrib=kousuke&Topsectionid=0 no matter what I do the morphs on these don't do anything? I tried to mail the author but had no response so far All suggestions welcome.
Hmm, I don't know :(
I downloaded one file and unzipped it. I see in the libraries folder folders for:
props
material
Inside the Props folder:
png
pp2
pmd
I don't know how to use pmd files.  Those are the morphs but how to incorporate them into the item is beyond my guess. I've never seen a package unzip like that before.
Letterworks posted Sat, 15 July 2006 at 5:25 PM
I THINK those are Poser 6 external morphs and I THINK you need to have that option turned on for them to work.
mike
nruddock posted Sat, 15 July 2006 at 5:53 PM
The morphs are in PMD format, so are you using Poser 6 ?
If not you'll need MorphExchange -> http://camelot.renderosity.com/freestuff.ez?Form.Contrib=kuroyume0161&Topsectionid=0
If you are using P6 then you may have to adjust the paths to the PMD files, as they appear to be expecting you to have installed the item in the Download Runtime.
simontemplar posted Sat, 15 July 2006 at 6:55 PM
I could use an example of how to use it in this specific occurrence x_x it tells me pmd reader errors
nruddock posted Sat, 15 July 2006 at 8:21 PM
So what version of Poser are your using  ?
What SR level is it at ?
Which of the clothing items for which figure are giving you trouble ?
On a random sample of one item (Mawashi_M3.pp2) the morphs work fine even though the PMD path is incorrect.
simontemplar posted Sun, 16 July 2006 at 3:32 AM
Those giving me trouble are the Mawashi, Rokusyaku Fundoshi and the Ecchu Fundoshi. All of them. I am using P6 and I did check the option "use external binary moprh targets".
TrekkieGrrrl posted Sun, 16 July 2006 at 7:17 AM
Just a note: You do not have to check the "Use external Binary Morphtargets" to USE PMD's. Actually I'll strongly suggest unchecking it. What it does is it SAVES everything with PMD's and that's asking for trouble....
I have that underwear but I've never used it, so I can't help with the actual question, just thought I'd peep in with the PMD thing :o)
