DarkEdge opened this issue on Jul 16, 2006 · 5 posts
DarkEdge posted Sun, 16 July 2006 at 12:46 PM
hi all!
for some reason i have different v3 figure files now. v3 rr, v3 sae, and v3. is there a difference between all of these?
it happened when i dloaded the free versions of v3 and m3 into poser.
thansk!
thefixer posted Sun, 16 July 2006 at 1:26 PM
V3rr Is reduced resolution.
V3SAE is the standard one to use for most things.
V3 is probably the one you had originally.
Injustice will be avenged.
Cofiwch Dryweryn.
BeyondVR posted Sun, 16 July 2006 at 1:31 PM
V3 SAE (Second Anniversary Edition) has the expressions and phonemes already loaded, like S3P, where the original did not. That's the one to use.
John
4blueyes posted Sun, 16 July 2006 at 1:33 PM
As thefixer says :) V3 RR is the reduced resolution version (she has less polygons than usual vicky, that is) to be used in backgrounds or in crowded scenes, as she is easier on Poser. V3 SAE is the base Vicky Special Anniversary Edition - V3 with all expression morphs already injected into her. V3 is the base one and afaik there were some minor bugs in her so V3 SAE is usually the most used one. Michal 4blueyes
DarkEdge posted Sun, 16 July 2006 at 1:44 PM
