Subject: creating a morph in c4d...what do i wrong??
SUNNY6767 opened this issue on Jul 29, 2006 · 6 posts
SUNNY6767 posted Sat, 29 July 2006 at 12:54 PM
What do i wrong creating a morph target .
I will create some head and chest morphs for Vicky 3.
1. I load vicky3   faceroom doesn’t work with Vicky in Poser I think….it’s a great pity
2. I say export>waveobj.
  1. I select fpr example the head only.
4 let the settings as they are or try to mark as morphtarget no world kord…
load in cinema 4d or metasequana
morph the head like I like it.
Export as wavefrontobj again. In cinema without askings about the settings.
Open Poser6 again same vicky3 figure
Than add the morphtarget from the saved obj file…
But when I turn the parameter a littele bit from the 0.0000 the head directly is destroyed and morph in outa space….
So what did I wrong or what have I pay attention for ??
Sorry for my rusty English and thanks for help.
nruddock posted Sat, 29 July 2006 at 1:26 PM
Quote - So what did I wrong or what have I pay attention for ??
You used C4D's built-in OBJ import/export which reorders the vertices and is what's causing the exploding.
Try using the Riptide plug-in by Spanki -> http://www.skinprops.com/fr_c4d.htm
SUNNY6767 posted Sat, 29 July 2006 at 1:31 PM
riptide i not easy to get......try a download sometimes....but members bandwith dont allows allways a download in this month.... :ohmy:
steveshanks posted Sat, 29 July 2006 at 2:42 PM
Try this tutorial Sunny, BUT just as a make do till you can get riptide, my tutorial is old and its a bodge........Steve
AntoniaTiger posted Sun, 30 July 2006 at 6:01 AM
You've got the basic Poser side of things about right. It depends just what sort of morph you're doing. but in Poser 6, at least, you can use existing morphs and magnets to get the shape you want, and spawn a morph target. Vicky and the other DAZ figures has the upper body split between three groups, rCollar, Chest, and lCollar. Most morphs for that area involve all three groups, which needs some care over the boundaries and editing of the CR2 so that one dial controls all three together.
Spanki posted Sun, 30 July 2006 at 2:52 PM
Quote - riptide i not easy to get......try a download sometimes....but members bandwith dont allows allways a download in this month.... :ohmy:
...apparently the download links were broken today.. they should be working now.
Keith
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
