Subject: Conforming Clothing Problem
BrianR opened this issue on Jul 30, 2006 · 3 posts
BrianR posted Sun, 30 July 2006 at 9:36 AM
I've grouped & conformed a dress I modelled but when the skirt section bends with the thigh it stretches & deforms at the join, is there a way of fixing this problem other than a custom morph?
Thanks
Brian
xantor posted Sun, 30 July 2006 at 9:49 AM
It sounds like you have to adjust the joints of the part that is wrong.
If you load a p4 conforming dress or one made for jessi etc then you can see how the bend, twist and side to side settings are set up there and copy the settings to your dress.
You can have your dress and the other one with the proper joint settings both loaded at the same time and swap between the two in the joint editor to check you have the settings right.
BrianR posted Sun, 30 July 2006 at 2:25 PM
Thanks, I'll give that a go.
