amacord opened this issue on Aug 02, 2006 ยท 7 posts
amacord posted Wed, 02 August 2006 at 4:55 AM
say, has this problem been solved in poser6?
thx, A.
stewer posted Wed, 02 August 2006 at 6:15 AM
Can you be more specific? What problem?
amacord posted Wed, 02 August 2006 at 6:48 AM
the problem with welded vertices...where people usually recommend to split them, you know what i mean? still the same in P6?
Andi
stewer posted Wed, 02 August 2006 at 7:28 AM
In Poser 6 you can turn of smoothing completely or set a max crease angle on a per-object base.
amacord posted Wed, 02 August 2006 at 7:54 AM
thx for the quick answer!
would you kindly set up a quick shot of a simple six-facet-box with welded vertices and with this max crease angle set accordingly? please do me that favour.....
bagginsbill posted Wed, 02 August 2006 at 12:49 PM
Both have smoothing turned on. The upper one has crease angle 100, the lower crease angle was 80. Since the edges are 90 degrees, the lower one is all crease no smoothing, the upper one is all smooth, no crease. Objects with various angles would have various parts smooth or creased as specified.
amacord posted Thu, 03 August 2006 at 1:43 AM
thanks a lot and big hands, bagginsbill, i owe you a drink....
A.
