Subject: Need a help with Poser Libraries
shalock opened this issue on Aug 04, 2006 · 3 posts
shalock posted Fri, 04 August 2006 at 7:00 AM
Good day to everybody,
I need a little help:
I´ve recently cleaning my Poser Libraries from old stuff that i dont use anymore, but some of this stuff has been removed deleting the folders, and now i have a really mess because i dont know for certain wich folders i still use and wich dont.
Its there any utility that helps me to clean my libraries and give me some control of the folders?
Thanx!
pakled posted Fri, 04 August 2006 at 8:28 AM
I think so..I think the one you're looking for is Correct Reference..whichever one it is..you should be able to find it in Freebies under utilities.
modus0 posted Fri, 04 August 2006 at 11:26 AM
P3DO is a wonderful utility for managing folders and letting you know what goes with what, so you can easily move or delete things.
It's also easier to navigate than the Poser Library interface or Window's folder structure, and you get thumbnails of every item in a folder.
You can find it in the freestuff section here, just do a search for P3DO.
