bostone737 opened this issue on Aug 09, 2006 · 9 posts
bostone737 posted Wed, 09 August 2006 at 10:19 AM
Hello, Is there a way to rename folders (the head and body morphs) in runtime to not begin with '!!' and not have poser do a search for inj files everytime? The '!!' really annoys the heck out of me. I need to have everything sorted and that just makes it difficult to sort. Anyone has any suggestions i would appreaciate it..
thanks
Indoda posted Wed, 09 August 2006 at 10:34 AM
The easiest way is to use either CRPro or PoserFileOrganiser both in the store here. Otherwise, it's a search and replace through all the files that refer to !! and remove etc.
The important thing is not to stop questioning.
- Albert Einstein
Indoda
modus0 posted Wed, 09 August 2006 at 11:25 AM
Yes, you can rename any folder besides the Poser "root" folders (i.e. Cameras, Characters, Poses, Props, etc.) to anything you want without breaking anything.
Dizzi posted Wed, 09 August 2006 at 11:29 AM
Any folder inside the library folders (camera/character/face/hair/hand/light/materials/pose/props) can usually be renamed without a problem. There are just a hand full of old products that have references to injection poses in the pose folder rather then the libraries/!DAZ folder, but those few can be adjusted easily with a text editor.
bostone737 posted Wed, 09 August 2006 at 11:52 AM
ahhh... thanks guys thats what i wanted to hear :) now off to find a tut to edit names with text editor :0
thanks again
modus0 posted Wed, 09 August 2006 at 12:22 PM
You shouldn't need a text editor to change the folder names, unless you're redirecting the path to things like geometry, morph inj/rem, or textures.
If all you want to do is rename folders/products (say, in the Pose folder), right-clicking on the file and selecting rename works just fine.
bostone737 posted Wed, 09 August 2006 at 2:19 PM
ya.. i wanna do some morph injections i the pose folder.. the head and body morphs for v3.. i tried changing there names and now if i load a morph that requires them inj's, poser asks me to search for them manuelly
modus0 posted Wed, 09 August 2006 at 2:28 PM
Hmmm.
Did you move or rename the !DAZ folder in the Runtime:Libraries folder?
Because otherwise you shouldn't be having any problems with inj morphs.
Dizzi posted Wed, 09 August 2006 at 2:30 PM
You should download an actual version of those morphs, as only the original release got that problem.
