Sat, Nov 23, 1:29 AM CST
Subject: Poser or Python
LunaFaye ( ) posted Thu, 17 August 2006 at 3:55 AM · edited Sat, 27 July 2024 at 12:34 PM
Is it possible to make a material file that will only add to the material that is already loaded on an object/figure?  For example, let's say I have a ball in a scene, and I already have a material loaded onto it, and I want to add a specially designed sub surface scattering to it, without removing the material that is already there.
Could that be done with a materials or pose file, or is that going to have to be a python script?
Luna Faye
EnglishBob ( ) posted Thu, 17 August 2006 at 4:55 AM
Attached Link: Shader Spider
A material file can't do it reliably (or even at all) as far as I know. I think you need Shader Spider. The link is to the PC version, but there's one for the Mac as well. I don't have it myself, but I hear good things about it, and the description matches what you want to do...
markschum ( ) posted Thu, 17 August 2006 at 11:40 AM
You should be able to do a mat file , but you would have to cut out all the code except the parameter you want to change. The standard mat file would contain all the settings for the materials .
A python script might be easier.
fuaho ( ) posted Thu, 17 August 2006 at 10:10 PM
Attached Link: How to overlay textures/Alphas...
I don't know if this will help, but it's worth knowing if you don't.
LunaFaye ( ) posted Thu, 17 August 2006 at 11:42 PM
Thanks for all the replies.  :)
Does anyone know of some good python script tutorials?
Luna Faye
