Subject: Okay i need advise on a few subjects that kinda fall under the same umbrella.
Methastopholis opened this issue on Aug 22, 2006 · 3 posts
Methastopholis posted Tue, 22 August 2006 at 4:29 AM
hey thanks for seeing if you could help 1st off
My PC it a little old . Im limited on Hard drive space and only have 512 ram , with that said . here my issues
A.    Is about rendering video output
   1.Video codec & audio codec . what is the best and most optimal in 3d performance  and  picture quality with
the option to edit?
Are some faster than other when render out a video?
Or  is that just depend on render settings or does  the Video codec & audio codec setting and compression? play
a major roll in render time?
B.     okay it there some sort of rule of thumb in  Video export resolutions settings cus im not getting the same
result
as i do when render out an image sequence. With  the same settings, video seem to lack quality and RES.
In video export Resolution, should it be the same size as the DoC window is  or is there a rule of thumb on how to
calculate the best settings and size ?    Or  does the camera act different when exporting video. cus you know
how can tweak camera attributes to make things more dementional  and give it depth. Camera acts the same as
if it was rendering a still shot right?
C.     Video Editing Tips and tricks and good habits?
  1. Well i have been rendering out my vids uncommpressed. Where a 60 second clips can get as big as  1 gig with
sound and shadows enabled and resolution 490X 500+ 2 figs..and with the bucket size cut in half to 32. And can
take 5 to 9 hours to render if im lucky.  I been have failed my last 3 or 4 times  and tell you the truth it has me
starting to consider  new software. But i  must say i love poser and content.
K so i been  learning a few video and audio software  to take some of the burden off poser like sound i been
useing Blaze Media pro simple edit and convertion ware it has all the same codec that poser uses.
Should i do all my video editing ,compression, resizeing and what not before adding my secondary audio to the
project or does that not matter?
when choosing an export setting like codec and compression  , when editing in another program are you locked
into useing  just those one's .  cus when i try to use differnt codecs i get a bogus outcome. when editing?
thanks for you time folks
If You could when awnsering Please put a  A. B. or C. next to  your awnser  so i know what issue you are refering too
 for me thanks
