Subject: Poser 6 - Lost my rendering window!
spyder97526 opened this issue on Aug 22, 2006 · 3 posts
spyder97526 posted Tue, 22 August 2006 at 4:32 AM
Ok, I wanted to expand my document window to fit my 2nd monitor, so I hit the little button that has the 4 corner marks on it to expand the window - I accidentally hit the dang thing again and BAM! No window!!
So I tried to resized the window to catch a little piece of it so I resized it to 5000x5000 - still no window!
I tried resetting the preferences to load factory settings...no window...
Uh, help!?
WhatIdo??
Acadia posted Tue, 22 August 2006 at 9:21 AM
If you are using Poser 6, there are 2 tabs that you have to look under to get things to go back to factory settngs.  One is specifically for the document window I believe.  Go to your preferences again and check the box for "factory settings" and remember to click the preferred state button. Then look under each of the tabs. Once you have found that second tab check or uncheck for your needs and then click "OK".  Then close and restart Poser.
spyder97526 posted Tue, 22 August 2006 at 3:24 PM
Thanks! I'll give that a shot :)
