Forum: Vue
Subject: rendering - bad pixels
murmur opened this issue on Aug 23, 2006 · 4 posts
murmur posted Wed, 23 August 2006 at 1:57 AM
How can I get rid of these bad pixels during rendering? Sorry when I'm duplicating thread, I've seen something about that, but now I can't find it.
Peggy_Walters posted Wed, 23 August 2006 at 8:13 AM
Check your material on the roof and see if it has a lot of reflection.  To me it looks like the sunlight may be causing that.
LVS - Where Learning is Fun!
bobbystahr posted Wed, 23 August 2006 at 12:28 PM
In Imagine3D it would be called specularity but I think Vue has it on the highlights Tab...set all to zero or a colour you want to see,and it will either go away or be improved if you add an appropriate colour. The higher the number the brighter and smaller the highlight, and lower numbers, non zero ones, will spread it over the whole surface if it operates anything like Imagine3D. IIRC the parameters are dull to shiny.
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
bruno021 posted Sat, 26 August 2006 at 5:09 PM
I think you have too high highlight values in the roof tiles material.
