Subject: importing poser obj and textures into 3ds max...?
DarkEdge opened this issue on Aug 25, 2006 · 2 posts
DarkEdge posted Fri, 25 August 2006 at 1:38 PM
does anyone know how to export poser obj's with their textures in place so you can open them pre-textured into 3ds max 8?
i run the python script "collect scene inventory" put all of that in a special folder, export a copy of the obj to that same folder and then import to max but the textures aren't following.
can someone help?
BeyondVR posted Fri, 25 August 2006 at 1:59 PM
Haven't used Max, but it should work if you have the textures in the same folder as the OBJ.  The MTL file will say which goes where, but has no path info.  You may need to check the top option in the export dialog, also.  Leave others checked.  That's all I can think of.
John
