Forum: Photoshop
Subject: Bendy Text?
FranOnTheEdge opened this issue on Aug 31, 2006 · 9 posts
FranOnTheEdge posted Thu, 31 August 2006 at 2:59 PM
I need to be able to put text on a UV map - as in this image (but printed, not hamfisted writing) is there a simple way to do this?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
Bez posted Thu, 31 August 2006 at 4:54 PM
Best way is to use the Warp Text button, should be on the Text tool bar. Click anywhere on your image, select the 'create warped text button' choose the style you want and type away :)
Bez :o)
FranOnTheEdge posted Thu, 31 August 2006 at 5:01 PM
Thanks mucho, I now have bendy text.  I like the way you can change the angle of the bend even after typing the text.
Only thing I haven't managed is the text upside down part.
Fran's Freestuff
Bez posted Thu, 31 August 2006 at 5:19 PM
You could always try rotating your Canvas, typing your text then flipping it back again...not sure what that will do to the look of your text, but it's worth a try :)
AdamWright posted Thu, 31 August 2006 at 6:15 PM
...or duplicate the text layer then go to Edit>Transform>Flip Vertical
tantarus posted Fri, 01 September 2006 at 2:15 AM
In CS versions you can attach text to a path :)
Tihomir
Open your mind and share the knowledge!
FranOnTheEdge posted Fri, 01 September 2006 at 4:28 PM
Quote - ...or duplicate the text layer then go to Edit>Transform>Flip Vertical
Aha, thanks that sounds handy.
Fran's Freestuff
bobbystahr posted Sun, 03 September 2006 at 12:41 PM
You could also Transform>Rotate it 180 as well
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
FranOnTheEdge posted Sun, 03 September 2006 at 1:56 PM
Ta.
Fran's Freestuff
