Subject: Poser 4 problem! (The font)
dakesson opened this issue on Apr 05, 2001 ยท 5 posts
dakesson posted Thu, 05 April 2001 at 4:51 PM
My problem is the following: The fonts are too big (well, it seems that it's only one font that this problem appears too! When I, for example, get into the "Animation Setup" (Animation -> Animation Setup...) the following appears: Animation Output Settings: <-- This is ok. Frame: <- this is also ok. But then: W and He is shown. Really too big! (Size 28 something maybe) 640x640 is shown ok. Then furher down, the text Frames Total Hour:Min:S " is shown. Too big! (notice that the 'S' should surely be 'Sec', but it doesn't fit into the window. What to do?" NOTE: I have included some .bmps for you to see so I get what I mean. Thanx in advance! Daniel
JKeller posted Thu, 05 April 2001 at 5:43 PM
That's going to be something you fix in your Windows or MacOS settings, I don't think there is any adjustment you can make in Poser itself.
Oh, and it's best to use .jpg or .gif formats to display images on the web.
Hope this helps.
dakesson posted Fri, 06 April 2001 at 5:31 AM
Well, ok. Thanx, but exactly where in Windows? (I use Win98) Daniel
ENGELKEN posted Fri, 06 April 2001 at 9:30 AM
Try returning to only the original fonts that came with your Windows, or go into Start, Settings, Control Panel, Fonts and start looking for that large font that looks like the one Poser is trying to use. Then delete it. Back up your fonts first would be a good idea and be prepared for a long trial and error session if you've installed a lot of new fonts. Windows is not kind when you add new fonts. It can't seem to remember where the default font is. The other possibility is that you've installed Adobe reader and one of the Adobe fonts is responsible...same thing, go into Fonts and delete all the Adobe fonts that it will let you delete. eng
dakesson posted Mon, 09 April 2001 at 7:47 PM
BIg thanx to ya ENGELKEN! The Adobe font was the problem! How did u know that?
