Subject: Oddities when Rendering in Poser
Mercytoo opened this issue on Sep 09, 2006 ยท 7 posts
Mercytoo posted Sat, 09 September 2006 at 2:38 AM
Hiya folks, Sorry if this is the wrong forum, but I wasn't sure where else to put this. I also appologise for the title, as I know it's not very descriptive, but I have no idea what's going on to give it a better title. Ok, so here's the deal... I've been having major computer problems over the last few months. I finally got around to replacing everything, and one component I had to replace was my main drive. This of course meant reinstalling everything. Once I got Poser 5 & some content back on, I decided to fiddle with it a bit to get everything the way I like it. Well, I loaded up V3 SR 2 and had some funky stuff happen when I rendered her. It didn't matter what texture I used. I no longer have those images, must have deleted them. So tonight, I spend about 2 hours setting up an image and another 45 minutes rendering. This time I used V3 SAE. The render finally completes, and there's the funky stuff on her head again! So my first thought was that I might need to update my video card drivers, so I did that, rebooted, and loaded up poser again... First I started with V3 SAE, with Daniella Texture. Got the funky stuff. Switched the texture to Daria, rendered again... more funky stuff. Then I removed SAE from the image and loaded up V3 SR2. I put the Daria texture on her, no funkies. Next, I removed V3 SR2 from the image and loaded up SAE Again, also with Daria. This time no funkies. I'm really boggled. I don't know what's causing this. As I said before, it happened to me with V3 SR2 a few days ago too. I'm hoping someone here can help me troubleshoot this. I mean, I know it's not the models... it has to be something with my PC, but I have no idea what. I've attached a picture so you can see just what's happening. Here's some info about software & my machine, just in case someone needs it: Windows XP Pro Poser 5 NVIDIA GeForce FX 5200 with up to date drivers AMD Athlon XP 1.1 gig (Same exact model I had before) 1.5 gig RAM Any help is greatly apprecieated, thanks! :D
