barrowlass opened this issue on Sep 15, 2006 · 11 posts
barrowlass posted Fri, 15 September 2006 at 9:19 AM
Hi everyone/anyone
title says it all really - I need a hollow cylinder (not like a torus), which I can use for props etc. I'd really appreciate a link or three (Hi Acadia, lol) where I can get one.
cheers
Sheila
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
EnglishBob posted Fri, 15 September 2006 at 9:21 AM
Attached Link: http://www.morphography.uk.vu/dlmagic.html
Try my Magic Tube - it has morphs, too!LostinSpaceman posted Fri, 15 September 2006 at 9:25 AM
Well shoot Bob! Ya beat me! I was gonna go into a short tutorial on taking the Poser 4 Cylinder and using the grouping tool to give the ends of the Cylinders new groups separate from the sides group and spawning her very own cylinder with removable ends prop. Guess there's no need now.
EnglishBob posted Fri, 15 September 2006 at 9:35 AM
Blows imaginary smoke from end of imaginary gun barrel ;) Go on, post your tutorial anyway! It has applications for more than just making a hollow cylinder.
jenay posted Fri, 15 September 2006 at 9:43 AM
Attached Link: Joe's Poser Primitives
Hi,I have a couple of Poser primitives in my free download area:
http://www.joes3dfantasyworlds.com/down/primitives/primitives01.htm
among them there is a morphing ring as well, you can adjust the thickness.
you may need to scale it in y-direction to adjust it.
or you may use my tubes.
hope this helps :)
barrowlass posted Fri, 15 September 2006 at 9:47 AM
thanx guys, just what I was looking for! Could do with tut tho, Mizrael - would come in v. handy (maybe if I can get my head round making props!)
thanx English Bob - I've d/l the magic tube - I'm off to have a play now
Sheila
LostinSpaceman posted Fri, 15 September 2006 at 10:06 AM
Create a second group called ends or two groups called top & Bottom and add the polygons for the ends to these groups.
Then click on the "Spawn Props" button.
Delete the original cylinder and you have left over an open cylinder with either two props called top & bottom or one prop called ends. You can then group them back together in the Heirchy window and the ends can open and close. Whallah. Simple as Sugar! Easy as Pie!
LostinSpaceman posted Fri, 15 September 2006 at 10:20 AM
barrowlass posted Fri, 15 September 2006 at 1:36 PM
thanx Mizrael - v much appreciate yr help - off I go to play again ;-)
Tashar59 posted Fri, 15 September 2006 at 3:07 PM
This is the sort of thing that the free modeler would come in handy for. Wings3D, would be a good start.
lesbentley posted Fri, 15 September 2006 at 4:14 PM
Thanks for the freebies Jenay!
