Subject: Thicker eyelashes?
tvining opened this issue on Sep 20, 2006 · 3 posts
tvining posted Wed, 20 September 2006 at 7:22 PM
I've been using Poser for quite a while, but the one thing I can't seem to figure out is how to make the eyelashes thicker--they always seem kinda weeny, and using the morphs doesn't seem to help much. Do I need to change the trans maps? I'm using V3. Thanks--T
schtumpy posted Wed, 20 September 2006 at 10:00 PM
You could try creating your own trans map for the lashes to thicken them yourself.  Are you looking for girth or length?
Tashar59 posted Wed, 20 September 2006 at 11:47 PM
Different transmaps can help. Look through all your texture for the figure you want to use and see if there is a thicker one. Remember, if it's V3 your using, check all your SP3,A3, and L3/madie textures.
There is also the poser scale factor at work. If your doing a portait/closeup image. Scale your figure up 1000%. Move your camara back with a focus of at least 120.
