Pedrith opened this issue on Sep 24, 2006 · 6 posts
Pedrith posted Sun, 24 September 2006 at 6:18 PM
Hi. I am still dabbling with getting the ocean waves right for animation and I was just wondering if the Fractal Function generator filter can be animated? I tried to animate a scene using the fractal function generator filter, that one of the carrara users uploaded, but the water goes all flat.
Also if I place a second camera in a scene how do I switch to look through the other camera? Can more than one camera be animated?
Again any help will be appreciated.
Sincerely,
David
MarkBremmer posted Mon, 25 September 2006 at 3:57 PM
Hi David, Yes, Fractals can be animated - but not for the Terrain Genrator, only on shaders or as a displacement map. Just keyframe the parameters like you would any other animation. Animating open water is no problem. Animating where the water meets the shore has some, um, challenges. Cameras: just click the the camera name within the Assembly Room window and you'll open a list of all cameras and camera-save settings. You can animate multiple cameras but will need to switch to the camera of your choice in the Render Room. Mark
MarkBremmer posted Mon, 25 September 2006 at 4:17 PM
Pedrith posted Thu, 28 September 2006 at 6:05 PM
Hi Mark. Thanks for the advice. I like the movie you posted and read your advice and and tried a couple things, but would you mind posting a quick tutorial on how you made the movie because my brain is just not getting how you did that. I really appreciate all your help. Sincerely, David
MarkBremmer posted Mon, 02 October 2006 at 7:21 AM
Hi David, I'll get to it in just a bit. Gone this past weekend and going nuts today... Mark
Pedrith posted Tue, 03 October 2006 at 5:09 PM
Thanks Mark. I really appreciate it. David
