mtone opened this issue on Sep 27, 2006 · 3 posts
mtone posted Wed, 27 September 2006 at 9:41 PM
I've seen some window props here in the free stuff section. Is there a way to combine them with a wall prop and at the same time, a light source can still go through it? Or will the wall prevent the light from shining through the window?
wheatpenny posted Wed, 27 September 2006 at 9:49 PM Site Admin
If there is an actual hole in the wall where the window is, the light will still shine thru, but not if you just stick the window to a wall with no hole.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
EnglishBob posted Thu, 28 September 2006 at 9:21 AM
Lights don't shine through walls - as it is in real life, so it is in Poser. But in the virtual world, you can apply a transparency map to the wall, and let there be light! If you need more help, give examples of the window and wall you want to use.
