LMcLean opened this issue on Sep 28, 2006 · 17 posts
LMcLean posted Thu, 28 September 2006 at 7:13 PM
chippwalters posted Thu, 28 September 2006 at 7:47 PM
You need to apply the map to the transparency channel for your object. This is done differently depending on which version of Vue you are using.
LMcLean posted Thu, 28 September 2006 at 9:58 PM
Quote - You need to apply the map to the transparency channel for your object. This is done differently depending on which version of Vue you are using.
chippwalters, I am including the image and the steps I have taken. I am using Vue 5 Infinite. First Image is the Function Editor. Please tell me how to do this. Thanks
LMcLean posted Thu, 28 September 2006 at 9:59 PM
LMcLean posted Thu, 28 September 2006 at 10:01 PM
LMcLean posted Thu, 28 September 2006 at 10:03 PM
chippwalters posted Fri, 29 September 2006 at 12:21 AM
Looks like you got it.
You might check out my tutorial on Mapping a tire:
http://www.altuit.com/webs/altuit2/vuelab/MakingaTire-PartIITextures.htm
and another on Mapping Notes:
http://www.altuit.com/webs/altuit2/vuelab/MappingNotes.htm
LMcLean posted Fri, 29 September 2006 at 1:11 AM
chippwalters, Unfortunately, I don't got it yet. Everything that is white is supposed to be transparent so I don't know what I am doing wrong. Only the black is supposed to be left, like an alpha map. If someone has done this before please chime in here. Thanks
videodv posted Fri, 29 September 2006 at 1:27 AM
Delete the node that you have highlighted (leave the color node conected) and connect the transparancy tab (on the bottom tabs to the right of the color node) to the picture connected to the color node.
LMcLean posted Fri, 29 September 2006 at 11:06 AM
LMcLean posted Fri, 29 September 2006 at 11:07 AM
LMcLean posted Fri, 29 September 2006 at 11:10 AM
chippwalters posted Fri, 29 September 2006 at 3:58 PM
videodv posted Sun, 01 October 2006 at 2:20 AM
Hi LMcLean
Sorry been away for a bit, did you get this to work ok! or do you still need the file.
Chip cannot upload your file as the link in down.
Videodv.
chippwalters posted Sun, 01 October 2006 at 2:29 AM
LMcLean posted Mon, 02 October 2006 at 11:46 AM
I actually figured it out but downloaded the file too! Thank you all for the help. chipp thanks for the file. Looks great and videodv for all your help too!
