Forum: Vue
Subject: misty mountains
persius opened this issue on Oct 02, 2006 · 7 posts
persius posted Mon, 02 October 2006 at 8:38 PM
Hello.
This will be a very simple issue for the experienced Vue5 users.  However, sinse I'm still trying to master the remaining few details, it's one that is eluding me.
I'm trying to create misty clouds over the mountain peeks I've created, but my attempts are not exactly working out for me.  I know that Vue5 does offer a method to create this effect, but I can't quite find out how.  I do have the Vue5 manaual and I'm still looking through it to find what I'm looking for.  If anybody can offer a solution to my problem, or, if you know what page the information is located on, I'd greatly appreciate any help you are able to provide.
Thank
JohnnyRoy posted Mon, 02 October 2006 at 9:56 PM
Add a Sphere and stretch it over the top of the mountains to form an oval. Then apply one of the Cloud Sphere materials in the “Clouds / Other Clouds” category. You may have to use several spheres with different Cloud Sphere materials depending on the look you are going after.
~jr
persius posted Mon, 02 October 2006 at 10:07 PM
Hi JR.
I did initially try the sphere as you suggested. I didn't stop to realize that multiple spheres are needed.  I'll certainly give your advice a go right away.
Thanks
agiel posted Tue, 03 October 2006 at 10:36 PM
You can also try it with one big sphere and a volumetric material. You will have to play with the material parameters for density and distribution in particular, and most of all, the scale. Don't be afraid to raise the scale a lot.
sirenia posted Fri, 13 October 2006 at 11:26 AM
Hi persius, I have done the misty cloud thing a while ago on one of my works see pic http://www.renderosity.com/mod/gallery/index.php?image_id=1286606&member However, i did not do this with the spheres technique as mentioned here, but instead i used the alpha's with clouds photo's that you can find in the 'Cerro Verde' and 'Bali' samples on the content CD that comes with Vue 5 Infinite (don't know if it is available in Esprit or lower) These will make up for more realistic fog/clouds than using spheres in my opinion. Wim 🆒
Society failed to tolerate me...
... and i have failed to tolerate society
sirenia posted Fri, 13 October 2006 at 11:38 AM
Forgot to mention that you can play with the color setting and density etc... of the alpha's. You can achieve every kind of mist, cloud and fog effect this way ! Try it out and be amazed :woot: Wim
persius posted Mon, 16 October 2006 at 6:22 PM
Hi Wim.
Thanks for the pointer.  I'm going to give it a go asap.  This sounds like what I've been looking for.
Rock on....
Cheers
