Colin_S opened this issue on Oct 04, 2006 · 4 posts
Colin_S posted Wed, 04 October 2006 at 6:53 AM
Is there a tutorial / thread on the Sketch Designer? Also can you change the Render default style?
I really like the Cartoon with Lines style, but the default is to render to full Texture shaded. Can I change this? I can get a Cartoon w/Lines figure image into Paint Shop Pro but the props or backgrounds are poorly shown. My ideal would be to compose a scene in Texture Shaded so I could check it then render it in Cartoon w/Lines. Is this possible? Is there another way?
raven posted Sat, 07 October 2006 at 2:48 PM
Colin_S posted Tue, 10 October 2006 at 3:20 AM
Got it, many thanks.
Even off a quick look before work, picked up 1 point I hadn't thought of, that lighting affects the sketch design and render as it does the full one
TrekkieGrrrl posted Tue, 10 October 2006 at 5:23 AM
You can "render" Cartoon-with-lines by making a one frame animation, if you want something that is larger than your workspace. Or just anitalias that and save the picture.
Cartoon-with-lines aren't renders per se, and they should not be confused with the sketch Designer in Poser. Cartoon-With-Lines is a good way of getting an idea of where the shadows fall on a Sketch render though :o)
