ClintH opened this issue on Oct 05, 2006 · 1 posts
ClintH posted Thu, 05 October 2006 at 4:27 PM
Visit Toon Boom Inc. in the Renderosity MarketPlace
The Leading Storyboarding System for Visual Storytelling
Toon Boom Storyboard is the leading storyboarding system for visual storytelling, perfectly suited to traditional and paperless methods. Truly completing the production pipeline, Storyboard helps you take an idea and translate it into a visual story that will become a complete production, whether animated or live-action. Developed in conjunction with expert storyboard artists, Toon Boom Storyboard speeds up production planning and enables studios to reach new heights with increased production integration. Its advanced features make it the tool of choice to create an entirely digital storyboard.
Toon Boom Storyboard provides a:
Ideal for storyboard artists
Essential for directors and producers
The power of digital storyboarding
Opening up on a user-friendly Welcome Screen, Toon Boom Storyboard comes with an easy-to-use interface presenting an elegant traditional panel window layout or an overview window layout that fits into your content creation process. The Storyboard interface is easily navigable using just a graphic tablet pen.
Feature List
Digital Drawing
Draw with a complete set of vector-based tools to create resolution-independent drawings, including:
Modify, transform or recolor drawing object brushstrokes and color fills
Create brush textures to recreate the look of natural media tools, such as graphite, charcoal or pencil
Manage color palettes using a color picker that supports solid colors, gradients and textures, as well as an independent transparency value for each color
Create and manage an unlimited number of layers in a panel, using the transparent layering architecture
Enjoy easy layer manipulation using drag-and-drop to rearrange layer order, swap layers between panels and merge layers together
Customize layer display (Hide or Visible, Rename)
Apply the Transform tools to drawing objects to prepare them for transformations in the animatic, including changes over time to the object’s keyframe position, scaling and rotation between the first frame and last frame in a panel
Captions
Include captions for each panel with information such as notes, dialogue, slug lines, costume
Use the Global Captions field for overall comments, production notes, storyboarder contact information, etc.
Create an unlimited number of panel and storyboard caption
Type notes directly into caption fields
Customize the caption categories
Save caption layouts as a template for future storyboards
Search tool to find caption text easily
Import TXT files directly into a caption field
Sound
Use voice annotation to add comments quickly
Add an unlimited number of voice annotations to a panel
Record voice annotations directly without using an external application
Timeline
Display thumbnail images for each panel
Manage panels and transition duration using drag-and-drop
Import an unlimited number of audio tracks
Expand sound files for overlapping dialogue, sound and music
Set sound file duration directly in the timeline using drag-and-drop
Display sound file waveforms to synchronize shots
Edit each sound file’s volume envelopes
Turn individual soundtracks on or off
Shift and shuffle selections, panels or sound files all at once
Image and Audio Libraries
Reuse assets from the built-in image template library including Characters, Locations,
Props and Actions
Access an unlimited number of user libraries easily to work with custom and frequently used drawings and sounds
Set user libraries as global to Toon Boom Storyboard or localize it to the current
Storyboard project
Import libraries from Toon Boom Harmony, Opus or Toon Boom Solo
Camera
Play back a panel with dynamic camera movement in real-time using the Camera tool at any time during storyboard development
Keyframe camera position, zoom and roll between the first frame and last frame in a panel
Create smooth camera movement using drag-and-drop camera path elements
Define ease-in and ease-out acceleration for smooth camera motion
Transitions
Place transitions between shots
Select different types of transitions (Cut, Dissolve, Wipe)
Define the length of the transition
Playback
Play animatic in real-time without any rendering, including all camera movements and synchronized sound
Play back the current panel or the entire storyboard
Toggle playback to loop storyboard output
Turn sound playback on or off
Import
Import TVG, OPT, PAL, SCAN, SGI, TGA, YUV, OMF, PSD, PNG and JPG image formats
Import a group of images to automatically create a storyboard
Import SWF animation file formats
Import PDF file formats
Import MP3, WAV, AIF and AIFF audio format
Export
Support SWF and MOV animation formats to export the current panel or full storyboard
Configure SWF and MOV formats (audio and video codec, compression )
Support PDF format
System Requirements
Microsoft Windows and Linux RedHat Systems:
Microsoft Windows 2000 SP2 and XP, RedHat Fedora Core 3
2 GHz Intel Pentium 4 processor (Recommended)
512 MB of Ram (Minimum), 1 GB (Recommended)
90 MB of available hard disk space for the software
nVidia video card fully supporting OpenGL with 128 MB of RAM
Monitor supporting 1280x1024 resolution and 24-bit color depth
Wacom tablets for drawing (Optional)
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
