Forum: DAZ|Studio
Subject: Problems with Daz
robin123 opened this issue on Oct 11, 2006 · 6 posts
robin123 posted Wed, 11 October 2006 at 6:38 AM
I have some props got all the runtime and all the other good stuff needed, but it doesn’t work in DAZ it is a poser 4 one, but all the others I have work fine If I do an import I can find the file but nothing shows up in the file. I Try to open it normally don’t work ether any help will be cool as this is doing my head in
RHaseltine posted Wed, 11 October 2006 at 8:21 AM
Is it set up with the Poser Runtime folder structure (a Runtime containing perhaps a Geoemtries folder, with a sub-folder for an OBJ file, perhaps a Textures folder with a fodler containing images and a libraries fodler with a character or props sub-folder holding the file for the item? In which case it should just need installing in the usual way for Poser content - the Runtime goes in a Poser content directory, with the sub-folders nestling in among the stuff you already have. Or is it just an OBJ file with textures? In whichc ase you need to use File>Import. If it's some other format (such as .3ds) it will need converting to OBJ before D|S can import it.
robin123 posted Wed, 11 October 2006 at 9:06 AM
Ok Bare with me I am a little new at this, how do I find the poser content directory in Daz? and to move them do I just click and drag? I ask this because I do now know how to install poser content on to Daz all the other poser stuff just put itself in the correct place when it comes to computer files I am a bit of an idiot. I do now the the format OBJ
So if you have an idiots guide to installing poser content I would love a copy
Propschick posted Wed, 11 October 2006 at 10:02 AM
I would go up to preferences and have daz search your computer for poser directories...then choose what you want to use.
Ever stop to think, and forget to start again?
RHaseltine posted Wed, 11 October 2006 at 2:14 PM
Have a look at this thread: http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2668542
OBJ is just a file format for models - I was really asking how the stuff you want to install comes, as a fiolder with some textures and one or two files that probably don't already have an application associated with them, or as a set of nested folders starting with a Runtime folder.
robin123 posted Thu, 12 October 2006 at 3:31 AM
Hi all thanks for all the advice I have got it sorted now it seams the zip file had another zip in it and I didn’t see it once I open that I could import the prop
