ragnar opened this issue on Oct 16, 2006 · 9 posts
ragnar posted Mon, 16 October 2006 at 3:43 PM
HI all, :huh:
I have recently purchased Daz Robospider. What I'm trying to do now is to deform its legs so that I get something like a "martian warmachine" like in the original war of the worlds movie..
Unfortunately the leg segments (composed by thigh, knee, shin and foot) don't have "scale" morph. I tried to apply a magnet on the shin but it won't work, while magnet work fine on other figures parts, like "James" head.
Could it be that some figures are locked or am I doing (probably) something wrong? :rolleyes:
Thanks for your help.
Ragnar
Jules53757 posted Mon, 16 October 2006 at 3:52 PM
They should work on everything with more then one verticle.
Ulli
Miss Nancy posted Mon, 16 October 2006 at 3:54 PM
magnets don't work on objects with insufficient vertices to support deformation. try bending the poser cylinder as an example.
diolma posted Mon, 16 October 2006 at 4:42 PM
Hi, ragnar.
Just to expand on what Miss Nancy said, Poser's magnets work by affecting the existing vertices of the underlying geometry. They can't (directly) affect edges.
Switch to a wireframe view to see the way the object (or part of it) is made up. Vertices show up as the "points" where lines (edges) meet.
Lines (edges) cannot be affected by magnets, only the vertices (points) where they join are affected.
Hope that helps (and that I'm not telling you anything you already know)
Cheers,
Diolma
ragnar posted Mon, 16 October 2006 at 4:52 PM
Thank you all!
I'll see what I can do in Photoshop..
@Diolma : ..didn't know that :)
EricJ posted Mon, 16 October 2006 at 6:02 PM
Attached Link: http://www.daz3d.com/shop.php?op=itemdetails&item=2280
Did you know that DAZ has a martian tripod in the PC? (see link)On the other hand the martian machines in the original movie didn't have legs. In that case you could just make the spider's legs invisible.
Little_Dragon posted Tue, 17 October 2006 at 5:04 AM
Check the legs' properties panels. In all likelihood, the author has disabled the Bend option to simulate mechanical joints. Unfortunately, this also makes the body part immune to magnets and other deformers.
You can temporarily re-enable the Bend option, magnet the heck out of it, and create morphs, if necessary.
pakled posted Tue, 17 October 2006 at 6:56 AM
..and the reason they didn't have legs in the original movie was that the special effects weren't up to realisitic legs at the time (maybe stop motion, but the producers didn't go with that)..;) more useless facts from Pakled..;) Actually, I think you're referring to the '50's version (George Pal?) wouldn't be surprised if there were versions previous to that, tho.
EricJ posted Tue, 17 October 2006 at 11:26 AM
Quote - ..and the reason they didn't have legs in the original movie was that the special effects weren't up to realisitic legs at the time (maybe stop motion, but the producers didn't go with that)..;) more useless facts from Pakled..;) Actually, I think you're referring to the '50's version (George Pal?) wouldn't be surprised if there were versions previous to that, tho.
I did a quick search and the 1953 movie is the oldest I could find. I did find a neat site with blueprints for the 1953 war machines though. :)
