kelkor opened this issue on Oct 17, 2006 · 6 posts
kelkor posted Tue, 17 October 2006 at 10:03 PM
Any help would be great. Even if you have other tips I will listen.
Thanks
Kelkor
kelkor posted Tue, 17 October 2006 at 10:04 PM
nickedshield posted Tue, 17 October 2006 at 11:02 PM
One of the fastes ways to set the shoes and feet: start form the default position,IK OFF,zeroed, don't load the shoes yet. Set the right foot bend ~30. toe~25. Use the symmetry command to copy the right leg to the left Load shoe and conform doe the same with the other. Use the fit shoe morph in the feet of V3 to get rid of poke trhu. Look at the heel of the shoe, if it's flat on the ground you have it otherwise, tweak the foot bend and the toe bend as needed. Each set of high heels maybe different but this will quickly get you in the ball park.
geoegress posted Tue, 17 October 2006 at 11:32 PM
or you could just select the toes on each foot and set the min and max trans to 100%
Acadia posted Wed, 18 October 2006 at 5:25 AM
Or you can do what I do.
I rotate the figure on the Y Axis and from the side I select the right foot and move the Bend, Twist and Side to Side dials until the heel is flat on the ground. Then I select the right toe and bend the toe until the ball of the shoe is flat on the ground. Then I repeat the process for the left foot and left toe. Then I turn the figure facing the camera and if needed I will use the side to side dial again to turn the foot a bit if the foot isn't supposed to be exactly flat IE: resting partially on the inside or outside edges.
Once I'm done i return the Y Axis to zero.
Sometimes I use the Pose camera (right click in the pose window and pick "Pose Camera". When done, right click again and pick "Main Camera". This way you don't change your main camera perspective)
say." - Ghandi
billy423uk posted Wed, 18 October 2006 at 8:42 AM
would hiding the toes work
billy
