kawecki opened this issue on Oct 30, 2006 ยท 12 posts
kawecki posted Mon, 30 October 2006 at 7:18 PM
I want to make some morphs, with magnets there's no problem, but I want to do the morphs with some external application.
I can export the body part as obj, morph it with some program and then load as a morph target, until here no problem.
The problem is when I want to morph a body part that involves not only one body part, for example making a breast morph it involves the Right Collar, Left Collar, Chest and maybe abdomen.
I can export all these parts, but in the exported obj the vertices are not welded between the different parts. If I try to morph all the mesh appears cracked in the not welded vertices.
I can import, dismember and load each part as morph, but the result is not good due the mesh is not continuous.
If I weld the exported object, I can morph correctly it, but welding destroys the vertices order and the result cannot be used as morph target, if you do it the figure explodes!
How do you people solve this problem or what you do?
Stupidity also evolves!
