Forum: Vue
Subject: Shadow map issue (Vue 5)
RyanSpaulding opened this issue on Nov 07, 2006 · 4 posts
RyanSpaulding posted Tue, 07 November 2006 at 9:12 AM
Hey guys,
Having an issue with shadow maps here.  I've got the size of the map set to 4096, but I'm finding the shadow map isn't hittin everywhere I want it to..such as illustrated below.
Is there anything I can do to fix this?  Should I bump the setting even higher?
-Ryan Spaulding
 VueRealism.Com
bruno021 posted Wed, 08 November 2006 at 8:38 AM
A shadow map set at 4096 is probably already more complex to compute than a raytraced shadow. Are you using this map for the sun? Are you sure the mesh isn't the problem?
RyanSpaulding posted Wed, 08 November 2006 at 9:34 AM
Quote - A shadow map set at 4096 is probably already more complex to compute than a raytraced shadow. Are you using this map for the sun? Are you sure the mesh isn't the problem?
Yeah, it is a bit more complex to compute...takes FOREVER when it reaches glass but I didn't want to ramp up my AA for the entire image.
If I use standard raytraced shadows, this crease isn't there so I don't think it's a mesh issue.  Those faces completely touch and are solid so there shouldn't be a light leak anywhere.  And yes, it is the sun that I'm using.  It's the ony light in the scene.
I may just have to Photoshop it and just watch for this with shadow maps
-Ryan Spaulding
 VueRealism.Com
bruno021 posted Thu, 09 November 2006 at 2:45 PM
Maybe raytraced shadows with more AA will be quicker than this huge map. But I can't be 100% sure.
