Forum: Photoshop
Subject: Two simple questions.
mlofrano opened this issue on Nov 08, 2006 · 9 posts
mlofrano posted Wed, 08 November 2006 at 4:44 PM
First, is there a way to change the place a twirl is executed.  I would like it so that the twirl takes place in a corner rather than in the center of the image.  You know like when you use frre transform and you can change the point where the transform takes place from.
Second, a newb question.  How do you create a series of rectanges spaced equally either horizontaly or veritcaly without using rulers.  Let's say I want to draw seven 1 inch rectangles running from the  top to the bottom of the image, all spaced equally from each other.  I know I've seen this technique somewhere where you can just repeat the rectangles and they are equally spaced.
Thanks so much.
