Angelouscuitry opened this issue on Nov 11, 2006 · 15 posts
Angelouscuitry posted Sat, 11 November 2006 at 3:07 PM
A couple years ago another member offered me a pose the organized all of my V3 MTs into groups. When I ran it, it worked beautifully, and I hav'nt needed it since.
Lately I've been doing work with David, and M3. So I went looking for the author of this pose to see if she has made a similar preset for either of those figures, but I ca'nt find it.
Has anybody seen it?
nickedshield posted Sat, 11 November 2006 at 5:00 PM
Could it be PoserDialSorter by Wolfie?
Adavyss posted Sun, 12 November 2006 at 2:41 AM
Angelouscuitry,
You can easily write your own pose with any text editor.
First plan what your Morph Groups organization will be.
The pose structure is:
version
number 4.01
actor head
channels
groups
groupNode Morph
groupNode Characters
collapsed 1
groupNode Non-Humans
collapsed 1
groupNode Head Shape
collapsed 1
groupNode Expressions
collapsed 1
groupNode Transform
collapsed 1
parmNode taper
parmNode scale
parmNode xScale
parmNode yScale
parmNode zScale
parmNode yrot
parmNode zrot
parmNode xrot
It is just an exemple for the head where you end up with 3 main Groups: "Morph", "Expressions" and "Transform", 2 sub-Groups in the Morph Group: "Characters" & "Head Shape", 1 sub-Group "Non-Humans" in the "Characters" sub-Group. You've got the idea... add a groupNode "name" command for each Group (sub-Group, sub-sub-Group...)
Load the figure, load the pose and drag the morphs in the relevant Group. Save the CR2.
If you know the morph names and where they are supposed to go, then add a parmNode "morph name" command under the collapsed 1 of the Group, sub-Group, sub-sub-Group..
Hope it helps
Dizzi posted Sun, 12 November 2006 at 9:28 AM
Err, why not create the groups inside Poser, too? ;-)
Adavyss posted Sun, 12 November 2006 at 10:07 AM
Dizzi,
For a single figure, it's probably not worth it, but if you use the same morph organisation, you can apply the same pose file on any figure and then, it's far quicker.
and because...... Angelouscuitry asked for it.
Dizzi posted Sun, 12 November 2006 at 10:34 AM
While we're at giving all possible solutions: You can do it inside Poser first and then extract the grouping part (with all morphs) from the cr2/pz3 afterward, too. And here are some dial groups, for V3/M3/SP3 can be found, too.
Angelouscuitry posted Sun, 12 November 2006 at 5:56 PM
:tt1:
Adavyss - Thank you so much, that must have taken hours! It all looks cool and technical...I'm not sure what to say! The last time I needed this file was a couple years ago. It would take me a week to finish what you started, maybe then just for one figure. I wish I had the time to make one of these for David, M2, and/or Stephanie; then provide them as Free stuff! Or the money to pay you to fininsh, or just pay you to finish!
DIzzi - Your idea alomost hits home. I could make my first run spinning dials, and organize as I go. If there was simple way to then extract how I'd grouped, afterward, that would be something really nice to pass on to the next person! But, I do'nt think Daz3D would be too Kosher on the idea of doing that with the morphs. So, we'd have to strip them out somehow, which also may get too complicated to do out of the blue?
:tt2:
Dizzi posted Sun, 12 November 2006 at 6:57 PM
The grouping is separate from the other data in any of the actors (as Adavyss example above shows). So either cutting the data out or the other actor data from a cr2 isn't too hard and won't contain any morph delta data.
nruddock posted Sun, 12 November 2006 at 7:10 PM
The morph grouping information is in it's own section of each actor in a CR2 or PZ3, so you can make a pose for it by collecting just that information using a text editor or MorphManager.
Angelouscuitry posted Sun, 12 November 2006 at 9:41 PM
Adavyss posted Sun, 12 November 2006 at 10:38 PM
Angelouscuitry posted Sun, 12 November 2006 at 11:42 PM
Adavyss posted Sun, 12 November 2006 at 11:54 PM
Attached Link: Dimension 3D
Ralf Sesseler has some dial groups on his website: **Freebies** -> [Poser stuff](http://www.ralf-sesseler.de/d3d/content/free_en.html)........then provide them as Free stuff..... Well, everybody has his own idea of what the morph grouping should be. IMO, in such a case, it's more useful to explain how to do your own.
Angelouscuitry posted Mon, 13 November 2006 at 3:51 AM
Bingo, Woo whou!
Adavyss you're such a huge help, I appreciate your help and generosity, thank you so much again! I'm going to rename this as best I can and back them up on a hand full of disks!
Having these is such a time saver, and it makes your first run through the dials so much more aroganized, then there's just a little tweaking here, little tweaking there, and you'll never change it.
JQP posted Wed, 15 November 2006 at 8:03 PM
Adavyss, I use those freebie ones you linked to, but your tut has me wondering if it's possible to write in how to sort the transforms as well (never understand why morph groups are placed atop transforms, much less why the transforms are sorted as they are)?**
