onefromb5 opened this issue on Nov 26, 2006 · 12 posts
onefromb5 posted Sun, 26 November 2006 at 2:05 AM
I want to merge 2 pictures one ontop of another both are the same size. HOW do I do this in photoshop?
Thelby posted Sun, 26 November 2006 at 2:32 AM
Open both in Photoshop, then Click on the one you want on top and drag it over into the other picture. Then you can set your opacity so that you will be able to see both. There are other ways of doing this, but this way is the simplest to explain.
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
onefromb5 posted Sun, 26 November 2006 at 10:41 PM
ok i guess I should have said I want to use certian things from a picture and place (overlay) then onto another picture. How do I do that?
dreamer101 posted Sun, 26 November 2006 at 10:55 PM
You do a selection of those certain items on one image and go to Edit > Copy. Using the Move Tool drag selection to other image.
retrocity posted Mon, 27 November 2006 at 9:35 PM
@ **onefromb5,
did you try dreamer101 suggestion? You can also do a quickmask to "hide" the pixel you don't want in the first image and this'll let the underlying image show through...
onefromb5 posted Mon, 27 November 2006 at 9:55 PM
didnt try it yet... I will try it prob this wed evening when I have time to mess with it. I really havent messed with PS alot. mainly used it to enhance photos. nothing like this yet.
onefromb5 posted Mon, 27 November 2006 at 10:06 PM
dreamer101 posted Mon, 27 November 2006 at 10:23 PM
Just go to your Layers palette and change order of the layers. Grab bottom layer and drag to top or drag top layer to bottom.
Thelby posted Tue, 28 November 2006 at 11:06 PM
I would rather
onefromb5 posted Wed, 29 November 2006 at 1:20 AM
THATS IT THELBY....Thanks alot.
onefromb5 posted Thu, 30 November 2006 at 10:55 PM
Thelby posted Fri, 01 December 2006 at 11:54 AM
Very Cool. Do you plan to texture or add some color to the white areas??? It would look really neat if yoiu did!!!
I would rather
