Forum: Blender
Subject: Modeling a jug
Tobak30 opened this issue on Dec 05, 2006 · 4 posts
Tobak30 posted Tue, 05 December 2006 at 8:35 AM
I wonder if there are a tutorial out there where it is shown how to make the handle on a jug.
Thanks in advance for all help.
oodmb posted Tue, 05 December 2006 at 11:51 AM
there is a tutorial for making a hole in a box,  basicaly the technique is the same except you extrude the hole to make a cylinder, then curve it to meet back with the jug.  make another hole in the where the cylinder meets it, and then attach the end of the cylinder to the jug using ctrl m or f .   edit the verticies manualy before you do the extrusion of the cylinder to be the handel
Tobak30 posted Tue, 12 December 2006 at 8:37 AM
I found another tutorial. But I don't remember the adress.
There you built the shape of half your jug. mug or cup. whatever you wanna make and uses the spin function. then you extrude from that form the handles. using make vertixes and fill faces to join one part of the handle to the other one.
By using the knife function you can also make the edges more marked. then you just aplay subsurf to get it nice and smooth. :)
Hope it helped. It was just a different way of making it.
oodmb posted Tue, 12 December 2006 at 11:40 AM
i actualy dont use the spin function because when i started using blender i did not know what remove doubles did.
