Subject: Visible in Ray Tracing?!
TrekkieGrrrl opened this issue on Dec 11, 2006 · 17 posts
TrekkieGrrrl posted Mon, 11 December 2006 at 5:58 AM
OK am I misunderstanding something here? (not unlikely)
Shouldn't things that have Visible unchecked, but Visible in Raytracing CHECKED show up in a reflection?
Mmm... and I vaguely remember something about Smooth Polygons should be.. what? On or off for things to show in reflections...
Anyway, isn't this what Visible in Raytracing is for?  Or am I once again expecting Poser (6 for some hours more...) to do something it can't do?
tez12 posted Mon, 11 December 2006 at 6:06 AM
With Visible in Ray Tracing turned on and the Materials refelection node Lighting/ Raytrace/Reflect there should be reflection and that is what  Visible in Ray Tracing is for as far as Im aware.
This works the object has to be visable and http visable for raytracing.
tez12 posted Mon, 11 December 2006 at 6:30 AM
Casette posted Mon, 11 December 2006 at 7:01 AM
I've done a quick  test just now and this is the result:
JAMES IN FRONT OF A CLOTH PLANE WITH A REFLECT NODE. FIREFLY RENDER. So I take James body and
  1. Checked both VISIBLE and VISIBLE IN RAYTRACING
         Result: James and a nice reflect of James
  2. Checked VISIBLE and unchecked VISIBLE IN RAYTRACING
         Result: James and a empty reflect (no James reflected)
  3. Unchecked VISIBLE and checked VISIBLE IN RAYTRACING
         Result: no James, no reflect of James
I suppose you're in search of the opposite of 2) : Nobody in scene and a figure appearing in the reflect, but... it looks like doesn't work
So... that's all, folks :)
CASETTE
stewer posted Mon, 11 December 2006 at 7:06 AM
Quote - Shouldn't things that have Visible unchecked, but Visible in Raytracing CHECKED show up in a reflection?
No, they should not. Only things that are checked to be visible are passed to the renderer. The renderer then adds only those with "visible in raytracing" to the raytracing data - the rest will be visible directly, but invisible to any raytraced effects.
tez12 posted Mon, 11 December 2006 at 7:08 AM
For Nobody in scene and a figure appearing in the reflection you can add a image reflection, that works and looks as good.
Image based reflection.
CaptainJack1 posted Mon, 11 December 2006 at 7:31 AM
I've always had trouble with ray traced reflection in Poser... surface artifacts, groups not visible to the camera not appearing in the reflection, all kinds of things. If you don't mind the extra hassle, you can export your scene to another renderer, which has all sorts of other advantages, too. I did the above example in POV-Ray, and added one extra command in the second example to turn off the image but leave its reflection, and a second command in the third to turn off the shadow.
Just a thought. 😄
TrekkieGrrrl posted Mon, 11 December 2006 at 7:31 AM
Yes that looks ok but it's not useable in the specific situation though.
What I needed was a way to look through a wall but have the wall (which is part of a train compartment so it's a bit more than just a wall) show up in the reflection in the window.
But I guess that's not possible then. OK at least I can stop trying and see if I can find a camera angle that allows me to see without being obstructed.
Thanks for the help guys :o)
tez12 posted Mon, 11 December 2006 at 7:34 AM
Sorry  but I dont understand ,  now if im getting it right do you mean you want a semi transparent wall that reflects, if so that can be done.  Like a windows with reflection.
tez12 posted Mon, 11 December 2006 at 7:53 AM
Right iv read it a few times and think I know what you are wanting. You want a 2 way mirror effect, so one side of the wall is visable so it reflects but the other side is transparent so your can view through it.
bagginsbill posted Mon, 11 December 2006 at 9:37 AM
This might work for you in this case. Make the wall out of a one-sided square. Turn it around so the "front" is facing away from the camera. In the preview, the wall will disappear as you turn it.  If you move your camera to the other side, you can continue seeing it while you position and size the wall.
Now go into your render options and enable "Remove backfacing polys". This makes the one-sided square truly one-sided!
TrekkieGrrrl posted Mon, 11 December 2006 at 9:53 AM
I mean that I'm standing int he side corridor of a compartment-type train, looking into one of the compartments.
The wall I'm looking through has a door and window panes (so it's not just a flat wall) - but the thing is the non-window'y parts of the wall and door is in the way. But since the character's image is visible in the window (looking out of the train) and the main thing is that you can only see the face in the reflection, I need those windows to also reflect the compartment door and dividing wall. And I can't make that out of one sided planes. The idea is good, it's just not possible here.
Anyway I decided to remake the scene from another angle, so for now I've solved that problem. -Now if only Poser would actually RENDER it sigh
dphoadley posted Mon, 11 December 2006 at 10:54 AM
You might try different renders, and then layer them in Photoshop.
Dzhugashvili's Gerbille
  STOP PALESTINIAN CHILD ABUSE!!!! ISLAMIC HATRED OF JEWS
bagginsbill posted Mon, 11 December 2006 at 10:54 AM
Oh well that's got nothing to do with invisible walls then. The problem is your camera is in an unreal location.
Put the camera inside the room.
Then either adjust your focal length down to get a wider angle shot, or raise (or lower? can't remember which works which way)  the "Scale" dial on the camera this makes it include more of the scene without changing the focal length. That way you can keep a long focal length, as if you were outside, but you're actually inside.
TrekkieGrrrl posted Mon, 11 December 2006 at 6:34 PM
Thanks, I always forget that you can scale cameras. I'm so used to the focal dial because I'm thinking in Real Camera terms.
As it is, the altered scene worked almost better than the one I originally planned, but I'll have to try scaling the camera and see if I could have done the first thing I had in mind, that way.
stormchaser posted Mon, 11 December 2006 at 6:41 PM
TrekkieGrrrl - Will you be posting your image when it's done, I'm interested to know how it turns out?
TrekkieGrrrl posted Mon, 11 December 2006 at 7:02 PM
Actually I have just posted it, and was returning here to post the link LOL So yes.
Here it is: http://www.renderosity.com/mod/gallery/index.php?image_id=1343929
