Subject: Shadowproblem!
factor opened this issue on Dec 12, 2006 · 7 posts
factor posted Tue, 12 December 2006 at 7:48 AM
Hi, me again...  :-(
I did a render with 3 Lights.
The Main-Light has Shadows enabled and its an Infinite-Light.
The 2 others are Spots and the shadows are disabled.
After rendering with Firefly i`ve got THIS Result:
Why are there such "lines" or "Distortions" on the skin?
Did anybody ever had such similar error?
Thanks to ya all!
Factor
dphoadley posted Tue, 12 December 2006 at 8:12 AM
Ucheck smooth polygons both in the Render Options menu, and in the properties menu fo each of the little girls body -parts.
Dzhugashvili's Gerbille
  STOP PALESTINIAN CHILD ABUSE!!!! ISLAMIC HATRED OF JEWS
Dizzi posted Tue, 12 December 2006 at 9:24 AM
It doesn't make any sense to turn of smooth polygons in render settings AND properties of the body parts... One of the two is sufficient...
factor posted Tue, 12 December 2006 at 9:39 AM
So.... thanx to you both:
Which one should i disable???
In my opinion it should be enough to disable it in the Renderoptions, hmm?
Greetz, Factor
dphoadley posted Tue, 12 December 2006 at 11:14 AM
My experience with Poser 5 is that if I don't uncheck both, while it won't smoth ALL polygons, it will still smooth the poygons of the checked items.  So to be safe, uncheck both.
Miss Nancy posted Tue, 12 December 2006 at 3:33 PM
the bear and the little thinker ain't casting shadows AFAICT. I was hoping they would have fixed this for default renders, but apparently not. I can't see the bear in the reflections on the boots, either.
dphoadley posted Tue, 19 December 2006 at 11:30 PM
Do what we suggested, Do a new render, and show us the results.
