Circumvent opened this issue on Dec 12, 2006 · 76 posts
Circumvent posted Tue, 12 December 2006 at 11:35 AM
I don't know if its me or not but Poser 7 renders look horrible. They look fussy and they are only 60 KB in size and when rendering the same scene into Poser 6 its like 280 KB and a very good picture. Is there a setting I need to tweak? I don't get it. Also, I can't load my Runtime folder into Poser 7 from Poser 6. Any help would be greatly appreciated. So far I'm not impressed.
Adrian
bluecity posted Tue, 12 December 2006 at 11:38 AM
Do you mean the JPG files it creates, or the output of the render window?
Klutz posted Tue, 12 December 2006 at 11:43 AM Online Now!
I have similar rendering issues! :0/
Just getting it do do a simple test render it struggles compared to P6 :0(
This is before you think about Exporting.
I posted fuller details on another recent thread.
Klutz :0(
Life is a beta.
In faecorum semper, solum profundum variat.
Circumvent posted Tue, 12 December 2006 at 11:47 AM
What I do is save the finished render in a JPG format with 0 compression and I also save it with 100 compression and both pics look like crap. The renders are 58 KB in size and that is so small. In Poser 6 I render the same scene and its like close to 300 KB and looks a million times better. It's like Poser 4 with bad textures.
Adrian
randym77 posted Tue, 12 December 2006 at 11:58 AM
What if you save it in a different format, like TIFF or BMP?
Klutz posted Tue, 12 December 2006 at 11:59 AM Online Now!
Here is what i posted in another thread...It may have got buried ;0)
' It seems to be awfully slow at a simple test render. I am really beginner level at this TBH.
I am talking minimalist stuff here, one figure and no props. One that I could do in P6 in about 30seconds seems to bog down and even freeze it.
I have backed off the auto Firefly render to draft quality, but it still seems awfully slow!
Must have some things checked as default that P6 doesn't I suppose?
Anybody else got an issue like this?
( For the record 2 Gig Athlon64 2 Gig memory and 128M GeForce Graphics. ) '
Klutz :0/
Life is a beta.
jimmy1 posted Tue, 12 December 2006 at 12:39 PM
Quote - What if you save it in a different format, like TIFF or BMP?
Saved as JPEG, 0 compression, 62KB; saved as TGA, 1915 KB. Now THAT"S compression! A little too much compression, maybe; load the TGA to Photoshop and save it as a JPEG at max quality (12) and it's 392 KB.
Tirjasdyn posted Tue, 12 December 2006 at 12:47 PM
What render settings are you using in firefly?
Klutz posted Tue, 12 December 2006 at 12:54 PM Online Now!
I was using auto default, but reduced it to auto draft. :0/
Life is a beta.
panko posted Tue, 12 December 2006 at 12:56 PM
( For the record 2 Gig Athlon64 2 Gig memory and 128M GeForce Graphics. ) 'Klutz :0/
Nige, try to find the latest driver for your graphics card --it makes a huge difference.
So far rendering works fine with me --and fast!... :)
Panos
"That's another fine mess you got me in to!" -- Oliver Hardy
Klutz posted Tue, 12 December 2006 at 1:00 PM Online Now!
Quote - > Quote -
Klutz :0/
So far rendering works fine with me --and fast!... :)Panos
I'll do that now, Panos....
Good idea..Thanks for the prompt!
Nige. :0)
Life is a beta.
Klutz posted Tue, 12 December 2006 at 1:42 PM Online Now!
Tried that....Graphics driver updated...Seems quicker graphics generally...
Hasn't solved the problem though...
One Sidney plus hair hit render on Firefly auto and it choks then freezes! :0(
Life is a beta.
tastiger posted Tue, 12 December 2006 at 1:46 PM
Can we see a sample just to compare - it's not an issue i have.
Show me yours and I'll show you mine - so to speak....
The supreme irony of life is that hardly anyone gets out of
it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
randym77 posted Tue, 12 December 2006 at 1:46 PM
Sounds like something is wrong with the JPG compression they're using.
Teyon posted Tue, 12 December 2006 at 1:46 PM
What are your settings? Can you post a screen cap ?
Tomsde posted Tue, 12 December 2006 at 1:47 PM
The difference well may be the system requirements of Poser 7 as opposed to 6. Compare system requirements, does P7 ask for more? It seems each new generation of software requires higher and higher computer resources. How much ram do you have? Perhaps it's time to add some more. Another thing that might help is to turn off all programs operating the in background.
SAMS3D posted Tue, 12 December 2006 at 2:16 PM
Do you have to adjust the hardware acceleration like in Poser 6? I have a dual core and duel Processor and hope there are no issues when I get mine. Sharen
pjz99 posted Tue, 12 December 2006 at 2:18 PM
P7 might ask for more, but it will very likely run very smoothly on LESS - just memory, I consistently had P6 go to 2gb and croak, while P7 has been pretty well behaved, at least outside of the cloth room (another story). I told Preferences to let the render run in a separate process and that is working well for me, you might try that and see if you get different results.
pjz99 posted Tue, 12 December 2006 at 2:22 PM
I don't know if you HAVE to do anything, but I was setting up and saw under General Preferences -> Render that the threads Firefly thinks it can spawn is set to 1 by default, so I changed it to 4 (max). I hadn't actually tried it with default, I'll do that though and see if it works the way it reads. Generally 1 thread = 1 core.
Klutz posted Tue, 12 December 2006 at 2:29 PM Online Now!
OK.
Tastiger: I have no render to show you :0(
Randy: Not getting as far as Exporting an image.
Teyon: I am just using 'out of the box' P7 Firefly settings.
Tomsde: I suppose it could be an issue, but th system is fairly well specced
see resume below.
2.00 Gig AMD64:
2 Gig RAM:
128Meg 6800GT Graphics ( updated driver today ;0) )
SAMS3D: Don't know TBH
PJZ99 : Never been an issue with Poser 6 ...Things running in the background and still churning out the basic test render I am referring to in about 30 seconds....P7 chokes and freezes.
Wonder if it could be Sydney or her hair, that is the only other difference ??? :0/
Thanks folks for the input so far!
Klutz :0)
Life is a beta.
Tirjasdyn posted Tue, 12 December 2006 at 2:36 PM
Have you tried not using default settings?
Going to manual and playing with the bucket size?
Miss Nancy posted Tue, 12 December 2006 at 2:47 PM
it's my hope these issues will be ironed out by SR2 or SR3. as in P5 and P6, one consequence of this early release (download) is to force early adopters to test the software under conditions the beta testers couldn't duplicate.
Klutz posted Tue, 12 December 2006 at 3:05 PM Online Now!
Miss Nancy! Ain't that the TRUTH! LOL
Tirjasdyn....... Where's my bucket? :0?
Thanks folks.
Klutz :0)
Life is a beta.
Teyon posted Tue, 12 December 2006 at 3:05 PM
It may be the hair slowing you down though to be honest, your system sounds pretty decent (though you may want a beefier display card). Did you set Poser to use more processes than just one? This may be slowing things down if you didn't. I myself am on a P4 with 2Gigs of Ram and a 512MB ATI card. I have Photoshop, Poser7, Windows Media Player, Outlook Express, Firefox and IE running. My renders or a single character with hair usually takes a bit less than three or four minutes depending on the hair and textures. That's at the highest setting.
You should fire off an email to tech support, as there may be something else slowing things down that you're not aware of.
Teyon posted Tue, 12 December 2006 at 3:08 PM
How is it when rendering from the Manual settings tab ? The bucket size and other nifty tidbits can be found there. The Manual Settings tab is right next to the Automatic Settings.
Klutz posted Tue, 12 December 2006 at 3:22 PM Online Now!
OK
Found it..
Bucket size it says 64
Shadowcasting and Raytracing are off.
Displacement 0
I'm trying it like this and see what will happen.
Life is a beta.
Klutz posted Tue, 12 December 2006 at 3:27 PM Online Now!
JPG compression 75
Life is a beta.
Teyon posted Tue, 12 December 2006 at 3:28 PM
That's really odd, your settings are the same as mine. I mean, up until yesterday anyway. I didn't switch on more processes than 1 until last night. I would contact Tech Support, it sounds like there's something in your configuration that they may need to know about.
Giolon posted Tue, 12 December 2006 at 3:34 PM
PUT NUDITY WARNINGS IN YOUR POSTS! Is it that hard? Some of us browse the forums at work and rely on these things to avoid NSFW threads. :-p
(Marked for nudity to tag the thread properly)
¤~ RadiantCG ~¤~ My Renderosity Gallery ~¤
Klutz posted Tue, 12 December 2006 at 3:35 PM Online Now!
I am pleased to have got it to render at all TBH.
Are the time and render about right for that or not then?
Klutz :0/
Life is a beta.
Teyon posted Tue, 12 December 2006 at 3:37 PM
Yes, that was an oversight on my part to remind ya - Nudity warnings are your friend.
Depending on how complex that hair prop is, 3 minutes could be about right.
Klutz posted Tue, 12 December 2006 at 3:43 PM Online Now!
Sorry about the nudity thing....
Didn't twig it was the first naughty posting...even without nipples LOL
Mind on about five diverse things at the moment TBH! :0/
Thanks for the input, folks.
Right.....On the face of it then, I just have the issue of the auto settings then, I suppose?
Klutz :0/
Life is a beta.
Teyon posted Tue, 12 December 2006 at 3:48 PM
Looks that way. You should send a message to Tech Support so that the problem is logged and I'm going to make mention of it to the product manager just so he's aware. It'll be best if you make a Tech Support request though because you know your system and what else you have on it.
Klutz posted Tue, 12 December 2006 at 3:59 PM Online Now!
Thanks for your help and patience ;0)
I'll do that, Teyon.
Uh Oh!
Links to support from the program aren't working either....Still links to curious-labs.
Tried substituting e-frontier...Not having much luck with that URL either.
Probably still the big download issue....
Ah well, I'll try another time.
Klutz :0)
Life is a beta.
Teyon posted Tue, 12 December 2006 at 4:02 PM
It looks like the site's having some issues at the moment, as I can't access them right now. It's probably a bit of overload with Poser's new launch. I'll speak with Uli tomorrow though, so he'll hear about your problem. He may not have an easy solution without you being able to provide your info so keep trying the TechSupport links.
Tomsde posted Tue, 12 December 2006 at 4:28 PM
J-peg settings in Poser have always been tricky, even a slight increase in output quality can create nasty looking, pixellated images. If you're planning on doing an post work on your images it's best to save as PSD (for photoshop users and Elements) or TIFF. Yes they take more memory, but they won't degrade on you.
You could also try a P4 engine render, depending on the look your after that might be good enough for some things.
Klutz posted Tue, 12 December 2006 at 4:38 PM Online Now!
Valid point, Tomsde.
I'll bear that in mind too, when reaching that stage.... :0/
Klutz :0)
Life is a beta.
Circumvent posted Tue, 12 December 2006 at 6:56 PM
Thanks for every ones help with this problem. It seems that Poser 7 is going backwards in regards of saving a quality image. I've always saved my work in a JPG format in Poser 6 with high quality and it looks great. With Poser 7, the quality is horrible. It seems I have to jump through hoops to make a normal JPG file that Poser 6 could do with no problems. With Poser 7 it doesn't even come close to the quality of Poser 6 out of the box. Is there some kind of setting that I'm missing? TIA.
Adrian
Natolii posted Tue, 12 December 2006 at 7:48 PM
I never save to JPG from Poser. I prefer to save to PSD and convert to Jpg in Paintshop where I can control the Compression and file sizes as needed.
This is a habit I adopted with Poser 5.
I don't have a problem with rendering. I have a preset I use and I don't see these issues at all.
Circumvent posted Tue, 12 December 2006 at 7:55 PM
Yes most people save in a PSD format but what I'm trying to say is, why does Poser 6 allow you to save a really nice JPG but Poser 7 doesn't? Poser 6 has always done that for me even though I shouldn't save my renders in a JPG format to begin with, but at least it gives me that option. Poser 7 doesn't have that capability yet.
Adrian
Natolii posted Tue, 12 December 2006 at 8:13 PM
I see what you are saying (Looking at a Render I did in P7). Looks like they are using a standard Windows Dialog for saving, rather than the previous dialog.
Curious that.
randym77 posted Tue, 12 December 2006 at 8:39 PM
I think this must be a bug. The file size should not be the same for a JPG of highest quality vs. lowest quality.
Circumvent posted Tue, 12 December 2006 at 8:47 PM
THAT'S exactly what I'm talking about. I hope it's a bug because that should never be touched or modified. Just my feelings.
Adrian
randym77 posted Tue, 12 December 2006 at 8:57 PM
I hope they fix this. For stills, yes, you can save as a TIFF or some such thing. But what about animation? I usually render as a series of still images, so if Poser crashes, I can continue where I left off. I usually use a quality of 70-80, and adjust the filesize in my animation app. Rendering to TIFF would take a lot longer, then I'd have to convert to JPG, since my animation program doesn't do TIFF.
tastiger posted Tue, 12 December 2006 at 11:54 PM
I know with mine and I use 2 monitors - it pops up a "quality" selection box after you hit the save as jpg button - you can then select from 0% - 100% - However, mine comes up on monitor 2 so I'm not sure where it will pop up on a single screen.
it alive.
Robert A. Heinlein
Windows 11 Pro
Jules53757 posted Wed, 13 December 2006 at 2:45 AM Online Now!
Found the same problem, doesn't matter what kind of quality settings I used for jpg's, in P 7 all renders have the same filesize and the same bad quality. :(
Ulli
soulhuntre posted Wed, 13 December 2006 at 3:23 AM
Quote - Rendering to TIFF would take a lot longer
Using JPG as an intermediate format is a bad, bad idea. The quality loss seams like a waste to me. That aside, renderign to TIF shoudln;t take any longer than JPG. Output format doesnt come into play at the render stage.
Sturm_und_Drang posted Wed, 13 December 2006 at 3:51 AM
Hi all,
I found exactly the same bug in Poser 7 here, ie do a quick test render and try to save as a jpg.
First, they have changed the dialog box so you get to choose the quality in a separate box now, and they don't bother telling you which is the good and bad end (not that I need telling but all the same... :) )
Also, no matter what setting you choose, all jpgs are indeed coming out at low quality. A TIFF looks fine though.
What I did then was to go back to Poser 6 just to make sure I was not just getting something wrong. I opened the last scene I had done in 6, and before I actualy did a render, I clicked on the render tab, and there was my Poser 7 pic!
I did the render, made sure I was right about being able to change quality, and then when I dragged the slider over, my new P7 pic was still there in the render stack!
How, I have no idea, I accepted default folders for everything, I have versions 5, 6 and 7 on this machine, and 5 & 6 never interacted at all.
Anyway, this was late last night, so I gave up trying to figure it out and I am pleased to see this thread to bounce it around.
Circumvent posted Wed, 13 December 2006 at 3:54 AM
I'm glad we all found the bug and lets hope they fix this with the first service release. I'm guessing everything else works OK like PSD, TIFF ETC? Thanks again.
Adrian
Natolii posted Wed, 13 December 2006 at 5:16 AM
Ratscloset has flagged this with Support.
http://www.contentparadise.com/forums/contentparadise/index.php?showtopic=2700&st=0&#entry18602
Circumvent posted Wed, 13 December 2006 at 5:22 AM
Nat
Oh cool then lets hope that EF will fix this in the first SR. Thanks for letting me know.
Adrian
randym77 posted Wed, 13 December 2006 at 5:46 AM
Quote - Using JPG as an intermediate format is a bad, bad idea. The quality loss seams like a waste to me. That aside, renderign to TIF shoudln;t take any longer than JPG. Output format doesnt come into play at the render stage.
That has not been my experience. I've found the quality makes a difference in speed, at least when using the "make movie" options.
JPG is NOT an intermediate format for me when I'm animating. It's the only format my animation software accepts. So if Poser can't do it, I have to convert each frame with Photoshop.
I mostly make small animated graphics for Web sites and such. It's pointless to render to TIFF format, when I'm only going to convert the frames to JPG anyway, and then convert to something even more lossy.
JohnRickardJR posted Wed, 13 December 2006 at 6:02 AM
Might be a strand hair issue - that's hair room hair you've got on that render there, and that really slows things down, even in P6. Try the third or fourth hairs for Syd instead
ThrommArcadia posted Wed, 13 December 2006 at 7:34 AM
Just throwing in my 2cents.
1. Graphics cards have no effect on rendering from what I understand. They effect display, and that's all.
I haven't hunted around too much and I'm at work right now, but from what I've found so far testure filtering is no longer a render option in P7, it is instead controlled on a texture by texture basis in the material room. Texture filtering really slows down a render and is not always needed depending on what you are doing or your own style. (PS, does anyone know of a way to just shut off all texture filtering? I hate the idea of having to go through a million textures on by one!)
I no longer use jpg, I only render to tiffs, but there is no technical reason that the render speed would change. The system has no clue what you are going to save to until after you render!
Just a few thoughts. Still, good to know about the bugs. I'm glad I read this, because far too often if I run into a bug I figure its just me. (Tech support on any application always treats me that way, at least and I'm more then just slightly computer literate. lol)
Hope they will resolve these issues soon.
Tirjasdyn posted Wed, 13 December 2006 at 10:08 AM
Quote - Just throwing in my 2cents.
Graphic's card drivers can affect things all through out a system. Updating a driver can fix or destroy a multitude of things. I kid you not...even printers can appear physically broken with a bad graphics driver.
that's why you hear the "have you updated your graphics driver" alot when dealing with computers. Poser is one of the few programs any more that does not rely on graphics card alot, except for display but it is leading that way with more hardware acceleration and opengl displays.
Crazy I know but graphics cards can make or break a system in ways that just don't make any kind of logic.
Klutz posted Wed, 13 December 2006 at 11:11 AM Online Now!
Quote - Might be a strand hair issue - that's hair room hair you've got on that render there, and that really slows things down, even in P6. Try the third or fourth hairs for Syd instead
You are probably right that that would probably make the situation worse,but.....
I think it was the Syd 3rd Hair IIRC....
Certainly was one of the default hairs anyway.
Haven't dared open the door to the Hair Room yet! LOL
Klutz :0)
Life is a beta.
Klutz posted Wed, 13 December 2006 at 11:24 AM Online Now!
Teyon...I have notified support as requested.
Many thanks for your time on this.
Klutz :0)
Life is a beta.
Teyon posted Wed, 13 December 2006 at 11:29 AM
No problem. It's always good to log these things instead of just letting them fly by or making cumbersome work arounds. If it's logged and we can repeat it, we do our best to fix it. :)
JohnRickardJR posted Wed, 13 December 2006 at 1:06 PM
The hair model in your render is the third item on the Sydney hair list, SydneyG2Strand_2, which is a hair room hair. One is the skill cap for the hair room, two and three are hair room hairs and four and five are prop based hair - 3 minutes isn't bad for hair room hair, at least for me!
This one has about 16,000 strands in it as initially set up.
JohnRickardJR posted Wed, 13 December 2006 at 1:29 PM
Just done a quick timing test to get an idea of the difference the strand based hair should make (quite late in the day and with a big project taking up lots of memory in the background, so ignore the actual figures and look at the difference between them).
Sydney with hair three (prop hair), standard render settings: 63 seconds
Sydney with hair two (strand hair), standard render settings: 12 minutes 20 seconds!
It's not normally that slow, but the ratio is about right.
JHoagland posted Wed, 13 December 2006 at 1:52 PM
Keep in mind that the FireFly Renderer in Poser 5 and Poser 6 had the option to turn "texture filtering" on or off. If you turned it on, textures would look sharper, even in the distance.
ThrommArcadia is correct: in Poser 7, this is no longer a user-changeable option. The manual says that tetxure filtering is turned on by default, but I'm seeing blurry textures in my scenes, especially when I compare the same image I rendered in Poser 6.
Also, the File > Export (to image) feature has been changed: you can no longer set the compression rate for any file types. I suggest saving the image as Photoshop, and then opening the file in either Photoshop or Paint Shop Pro and using those programs' "Save for Web" command.
Klutz posted Wed, 13 December 2006 at 2:10 PM Online Now!
Right...I must admit I wasn't aware those were styles created within the program.
Thanks for your trouble, JR.
It doesn't sound bad then for working on the default manual settings.
It is just the auto firefly settings which are giving me lock-up grief, bu the sound of it!
Once again thanks for the input, folks!
Klutz. :0)
Life is a beta.
nruddock posted Wed, 13 December 2006 at 4:46 PM
Quote - ThrommArcadia is correct: in Poser 7, this is no longer a user-changeable option. The manual says that tetxure filtering is turned on by default, but I'm seeing blurry textures in my scenes, especially when I compare the same image I rendered in Poser 6.
It may be on by default, but you can now set it on each texture to either "None", "Quality", or "Fast" using the new Filtering option on the Image_Map node.
A "change Filtering setting for all Images in a material" Wacro is probably going to be wanted.
Tirjasdyn posted Wed, 13 December 2006 at 5:03 PM
Quote - Keep in mind that the FireFly Renderer in Poser 5 and Poser 6 had the option to turn "texture filtering" on or off. If you turned it on, textures would look sharper, even in the distance.
Texture Filtering is under the imagemap node now and can be set for every texture...I plan to play a bit with it at home
Tomsde posted Wed, 13 December 2006 at 7:37 PM
If not animating it's always best to use a lossless file format to save your images, especially when working on them. Any computer graphics book will advise you on that. You can then output the final image to JPEG of GIF if posting on the web. TIFF and PSD will allow you to save layers, also a big point if you ever want to change anything in the image later. You can't save layers with JPEG.
yarddog posted Sat, 23 December 2006 at 8:49 PM
I have always saved in jpeg, in every other version of poser, sure hope they fix it in p7 soon.
Using p6 and p7 collecting virtual dust till they do. :mellow:
nruddock posted Sat, 23 December 2006 at 9:36 PM
Quote - I have always saved in jpeg, in every other version of poser, sure hope they fix it in p7 soon.
Why not save in a lossless format and convert to JPEG with another program.
It's usually best to convert to JPEG as the last step before uploading somewhere to avoid problems due to the lossy compression.
yarddog posted Sat, 23 December 2006 at 10:14 PM
How about just render in p6 and save time and space? No render speed diff between p6 and p7 if not using raytrace. Cannot see why I would want play with broken toy rather then the one that works.
Fraho posted Sun, 24 December 2006 at 1:37 PM
@Klutz: 3 minutes with one core is okay. Turn your render settings until the right-end, with P7 now it´s for me possible with 2 GB Ram (in P6 I´ve got an error with 70-80%).
By the way:
@pjz99 thanks for your hind with dual-core. It´s great! (maybe sometimes it´s for sure good to read the manual).
Merry Christmas
Frank
yarddog posted Sun, 24 December 2006 at 5:52 PM
The best true image export I have been able to export/save is by coping image from the
edit drop down menu and pasting in new file in photoshop all save as options were showing
quality loss. Must be something in the export script.
Tomsde posted Sun, 24 December 2006 at 6:24 PM
I've rendered several images in Poser 7 and have had no quality loss at all saving is PSD. I'll have to try a test render in jpeg and see it I notice a decline in image quality saving at the highest quality setting. It could be some conflict on your computer that's causing the degredation, every computer is different and therefore we can't completely rule this out. I'd also try email e-frontier and ask if they have any more data.
yarddog posted Sun, 24 December 2006 at 6:31 PM
Try pasting in compared to saving as is a bit of a difference here.
I would not expect a reply from e-frontier till later this week.
I just had a lil time to play today with export tests.
Now back to texture work.
Dizzi posted Sun, 24 December 2006 at 6:36 PM
e-frontier already confirmed that JPG compression setting isn't doing anything. I guess no one of the testers used that export option (why would anyone use it? ;-))
Teyon posted Sun, 24 December 2006 at 6:55 PM
Well, I did. I used it to see if it exported. Never thought to use it for dpi testing becuase I usually render out at 72 dpi regardless but with higher dimensions anyway. I'll take some of the blame on that one, though I wasn't the only person testing the program.
Teyon posted Sun, 24 December 2006 at 6:59 PM
The engineers will most likely have it fixed by the first service release. For those needing higher resolutions, I suggested (until the fix is ready) to do what I usually do out of habit: multiply the desired height or width in inches by the desired dpi to figure out what my dimensions would be.
Let's say I want an image that's 11 inches tall and 14 inches wide at 300 dpi. So the equivalent would be 11x300 =3300 and 14x300=4200 which means I'd render out at 3300x4200x72 dpi to get the same resolution.
yarddog posted Sun, 24 December 2006 at 7:16 PM
Suggest they do away with any compression on export. I only use dpi option when zooming in and out when doing area renders when texture testing so i don't have to change camera.
Never tried saving in higher dpi before as I agree no need unless your watching the paint dry.
