Subject: Expletives deleted...!
ziggie opened this issue on Dec 13, 2006 · 11 posts
ziggie posted Wed, 13 December 2006 at 2:34 AM
Is it just me.. or... am I right in saying you can no longer delete figures and/or props from your scene with the keyboard 'delete' key and can only do it from the Figure and Object pull downs now..???
"You don't have to be mad to use Poser... but it helps"
pjz99 posted Wed, 13 December 2006 at 2:41 AM
I have seen the same but it's intermittent.  Sometimes it lets me, sometimes not (mostly not).  I don't know the pattern yet.
My Freebies
Jules53757 posted Wed, 13 December 2006 at 2:48 AM
For me it works, looks like p / saves content before deleting for the undu-function. So, for heavy figures, it will take some seconds.
Ulli
ziggie posted Wed, 13 December 2006 at 2:51 AM
I have just done a P7 restart and delete key works at the moment, but earlier, it had no effect at all. Could only delete stuff from top menus...
LostinSpaceman posted Wed, 13 December 2006 at 3:09 AM
The Cloth room is clothifying figigures with multiple clothing item simulations for me. Just a dress worked fine, then just the pants. But adding a dynamic top after the pants and Sydney turns into Gumby!
nruddock posted Wed, 13 December 2006 at 4:24 PM
If the library palette has focus, i.e. was the last place you clicked, then the delete key moves you up one level in the folder hierarchy.
To be sure of deleting, click somewhere else on the screen (P6 was the same).
ziggie posted Thu, 14 December 2006 at 1:58 AM
@ nruddock... thanks, will check that out. I run dual screens and library folder is always open on one, so it could be that.
nruddock posted Thu, 14 December 2006 at 2:18 PM
This little UI gem was annoying in P6, it's still an annoyance.
pjz99 posted Thu, 14 December 2006 at 9:05 PM
You know, I still have this problem (delete key stops working to delete an object or figure).  This is even after selecting an object by clicking on it with the mouse, so I don't think it's that the library palette has focus.
My Freebies
Dark_Elf posted Thu, 14 December 2006 at 10:19 PM
but i found out if you change library (click on pose if in hair, etc) it suddenly works again
My Stuff:) You might hate it, but you never know...
Here
CP
Willber posted Thu, 14 December 2006 at 10:31 PM
Same here, sometimes it works and some times...not so.
