Subject: Something wrong with transparencies
kawecki opened this issue on Dec 13, 2006 · 27 posts
kawecki posted Wed, 13 December 2006 at 11:52 PM
A very simple scene: Take a cube, can be the box prop and set the diffuse color to red (255,0,0), specular and ambient color to black.
Now take the one side square prop or another cube and scale it up until is much bigger than the first cube.
Take the first cube and translate it up (ytrans) to the middle of the square prop, then translate it back (ztrans) until is some distance behind the square. You must not see it now.
Set the diffuse color of the square to green (0,255,0), specular and ambient color to black.
Now make the square 100% transparent.
The square is a green glass window and the cube is some object that you want to see through the window.
Render the scene and you will see nothing more than a red cube. Here is the problem!!!!!
The cube cannot be red, it must be black!!!!
You are looking through a green glass and the object has no green component in its color, it is red, so it must look black and never red.
Stupidity also evolves!
tekmonk posted Thu, 14 December 2006 at 12:25 AM
The problem here is that in real life, green glass is not '100% transparent', it is actually '0% R, 100% G, 0% B transparent'... ie if you shine a white light through it, it is transparent only to the green component and opaque to the rest, giving you green light. To duplicate this in CG, many render engines use a color value for transparency which they use in a similar fashion to color lighting effects, shadows etc and also correctly duplicate the effect you are talking about. Poser however treats it as a monochrome value so it wont have the same sort of result.... Maybe one of the tech guys can suggest an alternate solution.
Yet another reason to use other apps for rendering.
bagginsbill posted Thu, 14 December 2006 at 9:39 AM
The Diffuse_Color defines the color of light reflected from the surface. Had you made it somewhat less than 100% transparent, you'd expect to see green there and that is what would happen.
Poser should have implemented a Transparency_Color to specify the alteration of light passing through the object as you so rightly point out. However, if you think about 100% Transparency as meaning "not there" then this makes total sense. For example, when you use a transparency map for eye lashes, do you want it behaving like dark brown glass between the lashes or more like nothing there between the lashes? You want nothing there. It means "pretend the surface isn't really here".
Don't use transparency for glass. It isn't really intended for that. Instead, use the glass modelling features of reflection and refraction. Attach a Refraction node to the Refraction_Color input. If you don't want any light bending, set the Index_of_Refraction to 1. However, if you've correctly modelled the glass as a box (non-zero thickness) you should set the Index_of_Refraction to that of true glass, i.e. around 1.4. Adjust the "color" of the light passing through the glass using the Refraction_Color parameter. Adjust the amount of light passing through with the Refraction_Value parameter. If you want perfectly clear glass, use 1 there.
To get the full effect, you'll also want Reflection on this surface, with a Reflection_Value somewhere between .2 and .5 depending on how shiny your glass is. Also make sure you UNcheck Reflection_Lite_Mult and Reflection_Kd_Mult as these produce effects that are not based on realism.
bagginsbill posted Thu, 14 December 2006 at 10:01 AM
Here's a demonstration. The green glass is a scaled box, not a plane. As you described, because the glass only passes green light, the red stripes on the cylinder turn black.
Notice the double reflections in the glass? This is quite accurate, because light gets reflected inside the glass, between the front and back surfaces.
Notice also how the refraction has correctly bent the light from the cylinder, causing it to be shifted in position. You can also see refraction of the cylinder in the edge of the box.
Also important is to have some sort of environment for the reflections. I have a sky dome surrounding the whole scene, with clouds. This gives some interesting combinations in the glass, where we see reflection and refraction of the sky, or reflection of the ground and refraction of the sky.
bagginsbill posted Thu, 14 December 2006 at 10:08 AM
Here's another example. I changed the Refraction_Color to a minty pale green, allowing more of the red and blue through. I also lowered the Refraction_Value to .5, meaning this glass is not completely transparent, in addition to being selective about what colors to pass.
As a result, the second reflection of the sphere is much reduced. This is accurate, because that light had to pass through the front face, get refracted and reduced as it passed through the interior, then reflected off the back face, refracted and reduced again, and finally comes out the other side.
In this regard, Poser's handling of reflection and refraction is quite advanced. Instead of saying "Yet another reason to use other apps for rendering.", it would be more correct to say "yet another reason to learn how to use Poser's features properly."
Shall we talk about nostril glow? ;-)
bagginsbill posted Thu, 14 December 2006 at 10:17 AM
One more demonstration. Here I'm showing how the transparency parameter is properly used to implement "no glass here". I used a tile node to create four circular holes. I plugged that into the Transparency, as well as the amount of reflection, refraction, and specular reflection. This is the proper setup to use a mask on a transparent surface.
Notice that Poser has now correctly implemented not just the glass, but the partial shadow of the sunlight passing through the glass. Where light goes through the holes, the cylinder is fully lit. Where light has to pass through the glass, some of it is lost, so the cylinder is partially in shade.
I've seen lots of posts saying you should not use refraction and transparency at the same time. This is bogus - it works perfectly. You just need to know what each one is for.
Pretty cool huh?
stewer posted Thu, 14 December 2006 at 11:09 AM
Actually, to get the full glass effect, use the "fresnel" node. It does both refraction and reflection, mixing them depending on the viewing angle.
bagginsbill posted Thu, 14 December 2006 at 2:45 PM
Stewer,
You did not make colored glass. I agree that the Fresnel effect is very important for the realism of glass, and I should have talked about it. I figured kawecki was probably overwhelmed by all that new shader stuff and didn't need Fresnel that bad for flat glass.
However, I never use the Fresnel node for two reasons.
  1. You have no ability to control the amount of reflection. If you were doing a surphace with partially dirty areas, you couldn't adjust the reflection amount. And in general you need to adjust the reflection amount to deal with various levels of polish, clearcoat, etc.
  2. The fresnel node erroneously multiples not only the refracted light with the Refraction_Color, but also the reflected light. This is not at all correct.
Instead, I use the EdgeBlend node to make the reflection value depend on viewing angle. I use 1 minus that for the refraction value.
In the render above, the 3 balls on the left use Fresnel. The three on the right use Reflect, EdgeBlend (with inverse), and Refract. The top have Refraction_Color = RGB(140, 70, 0). The middle have Refraction_Color = (64, 128, 64). And the bottom have Refraction_Color  = RGB(255, 255, 255). The bottom left is configured just as your example above.
The shader tree is showing how the right-hand red ball is set up. The three on the right have the same nodes, just different Refraction_Color as described above.
But your example is a special case by not doing colored or darkened glass. As you can see, the color of the refraction greatly impacts the reflection. Of the left-hand spheres, only the bottom one is correct. So Fresnel is fine for perfectly clear glass. Otherwise, don't use it.
While you're at it, I didn't use it here, but the specular value should be multiplied by the same EdgeBlend as used for the Reflection_Value. I set the specular up the same way you did, but it's wrong. The right thing to do is turn off the default specular and use the glossy node, with the amount controlled by that EdgeBlend.
stewer posted Thu, 14 December 2006 at 3:07 PM
Well yes, in an ideal setting almost everything would go through the edge_blend node. In reality, there's barely any material that does not depend on the viewing angle. That said, not everyone is as fluent in the material room as you are - my solution is aimed at those who want the quick+easy glass look, and there the fresnel node is usually the better choice over using just refraction. Your setup does produce the more realistic appearance, no doubt.
TrekkieGrrrl posted Thu, 14 December 2006 at 3:26 PM
sits in awe
Bagginsbill and Stewer, thanks for the explanations! :o)
Miss Nancy posted Thu, 14 December 2006 at 4:15 PM
in regard to optics, litst explained many years ago (when folks were starting to import poser figures into carrara), that in the physical world, the sum of transparency and diffuse values hasta be
bagginsbill posted Thu, 14 December 2006 at 4:31 PM
Miss Nancy, you mean sum of reflection and refraction right? These glass materials have no diffuse.
And if you do it as I did, by definition the sum is one. Why? Because I defined the refract amount to be 1 - the reflect amount.
So
refract = 1 - reflect
therefore
refract + reflect = 1
qed
lupadgds posted Mon, 04 August 2008 at 10:21 AM
I try it and I make the same settings. Here is my picture. What do I wrong?
bagginsbill posted Mon, 04 August 2008 at 10:49 AM
Easy!
Diffuse_Value is 1. This means your object is behaving like milk. You want Diffuse_Value = 0.
lupadgds posted Mon, 04 August 2008 at 11:02 AM
*laugh* for you it is easy. Ok, thank you. This works fine! But now the next mistake I make. Don´t laugh about this stupid picture! Can you help me again with this?
bagginsbill posted Mon, 04 August 2008 at 11:08 AM
Sure. The Reflection_Value and Refraction_Value are multipliers of the amount of reflected or refracted light. These should not be so high as you have them. The Reflection_Value=4 means to reflect 4 times the light that is reaching the surface. Of course this does not look real, but can be fun for strange effects - as you can see.
(I think you missed the period? I was using .4 and .5, not 4 and 5.)
In real life, the maximum amount of reflection or refraction is 1. And, in fact, the sum of these can never be more than 1. If a photon reaches the surface, it can reflect, or refract, but not do both. These values, Reflection_Value and Refraction_Value, define the probability of what a photon will do. The photon can reflect or refract and you can adjust these probabilities, but they should never exceed one.
Actually, the full rule for physical correctness is this:
Diffuse_Value + Reflection_Value + Refraction_Value <= 1
At the time I posted this, I did not fully understand the rule, and I made a mistake myself. My first material uses .4 and .9, with a sum of 1.3. This is wrong, and is why the first glass looks funny.
lupadgds posted Mon, 04 August 2008 at 11:48 AM
Thank you. I don´t see this with my blind eyes! I change it to 0,4 and 0,5. It is better, but not fine. What is the problem? The light, the shadow or because I have no background?
bagginsbill posted Mon, 04 August 2008 at 11:55 AM
Both.
You should use an environment sphere. I have a free one here.
http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2746233
We have a problem with shadows through glass. You should be using IBL light, not just a single directional light.
Poser doesn't implement light passing through glass as a light source. So your shadow is 100% black. If you used "environmental" lighting, using IBL, that would not happen.
lupadgds posted Mon, 04 August 2008 at 12:02 PM
Ok, thank you. I try it tomorrow. Now it is 19:00 in Germany and I have to go with my doggie and then I look TV with my husband. If there is anything to ask you, I make it tomorrow. But also I show you the result with your sphere and new light. Thanks again. This was very helpfull for me.
lupadgds posted Tue, 05 August 2008 at 6:42 AM
Oh wow! Now it works! Thank you for this tip. Now I try the last picture you are posting above. I hope this works immediately for me. If not, I ask again *sigh*
lupadgds posted Tue, 05 August 2008 at 7:05 AM
Yes, it is also ok. But only question for this: what are the colours for the last balls (not the red and the green, the other balls) on the picture? Ok, now the last picture your post with the transparent. I try it now.
lupadgds posted Tue, 05 August 2008 at 8:25 AM
Ok, and here is the next. It is perfect! This thread was very helpfull for me. Great thanks to you bagginsbill! I hear from a nodes-club here in the net. Do you know about this something? I think this was the right place for me and I would give this a try, if I find this club.
bagginsbill posted Tue, 05 August 2008 at 10:43 AM
Lupa,
Nice work! You learn fast.
The clear balls use WHITE for the Refraction color. WHITE means it passes through unchanged - no tint. From the post above:
"The top have Refraction_Color = RGB(140, 70, 0). The middle have Refraction_Color = (64, 128, 64). And the bottom have Refraction_Color  = RGB(255, 255, 255). The bottom left is configured just as your example above."
The "club" you heard about is the "Node Cult" forum at RuntimeDNA. The link is here:
The Node Cult at RuntimeDNA
RuntimeDNA created that forum specifically for me. It's not for everybody, because we discuss very difficult shader node setups there. (My most complex shader ever was posted there - over 440 nodes.) But for those who really want to get into advanced shader techniques, it is a great place. Not only are there many very interesting topics to read there (with lots of math) but also there are many people who are interested to help with tricky shader setups.
Among those threads is one that you should read very carefully. Here it is:
** The Fresnel Effect - Glass, Paint, Plastic, and Metal
**I go into a lot more detail about glass in that thread.
bagginsbill posted Tue, 05 August 2008 at 10:46 AM
Here is what the monster 400+ node shader produces:
It is in this thread:
http://www.runtimedna.com/mod/forum/messages.php?ShowMessage=265218
markschum posted Tue, 05 August 2008 at 10:53 AM
Excellent BIll, * applause *
lupadgds posted Tue, 05 August 2008 at 11:42 AM
Wow! This is very nice! This was a hard work. Thank you for telling me the colours. And I visit the RuntimeDNA node cult.
See you later
Lupa
infinity10 posted Wed, 06 August 2008 at 7:25 PM
bagginsbill - awesome !
Love this thread.
Eternal Hobbyist
