jose473 opened this issue on Dec 14, 2006 · 7 posts
jose473 posted Thu, 14 December 2006 at 1:50 PM
What is the password for the zip file? I have tried the serial number for poser 7 and poser 6; my password at e-frontier; the order number; account number and nothing works. I can not unzip the file so I can't install, help!
Casette posted Thu, 14 December 2006 at 2:02 PM
Password???? Are you sure your zip file is OK? Mine unzipped without pass...
CASETTE
jose473 posted Thu, 14 December 2006 at 2:07 PM
I didn't want to heard that! I guess, I have a problem with the file, thank you!
Victoria_Lee posted Thu, 14 December 2006 at 2:45 PM
If you all are using WinZip are you accidentally clicking on the Encrypt button rather than the Extract button? I've done that a time or two (or more ... lol) myself. It's easy to do.
Hugz from Phoenix, USA
Victoria
Remember, sometimes the dragon wins. Correction: MOST times.
Spanki posted Fri, 15 December 2006 at 1:22 AM
jose473, if you are having trouble unzipping the file, the file is likely corrupt. The (Windows) file size should show up as: 1,774,803 KB (1.69 GB and 1,817,397,490 bytes if you do a 'properties' on it). My guess is that the download failed, somewhere before the end and you have a partial file.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
arcady posted Fri, 15 December 2006 at 1:59 AM
You might also have just found signs of a virus infection. If your file size is off from that above, don't just redownload, scan your system first if you feel that it seemed as if it had downloaded all the way.
Even if your filesize is smaller... Sometimes they don't just add, they replace.
A few months back there was a big virus in the Poser community - and the number one way it spread itself around files on the hard drive was that after it was there it would put itself into anything being downloaded or run.
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
Spanki posted Fri, 15 December 2006 at 2:04 AM
That's a possibility, but based on the trouble everyone is having with downloading a 1.7 GIGABYTE file, it's far more likely that the download just didn't complete. This happened to me 3 times, leaving me with a 600mb file, a 880mb file and a 1.3 GB file before I finally was able to download the entire 1.7 GB file.
