JQP opened this issue on Dec 17, 2006 · 7 posts
JQP posted Sun, 17 December 2006 at 2:35 PM
What do you do when you load a V3 character you've made, you inject some morphs, they don't work, you use the REM morph poses, inject the morphs again, and they still don't work?
P.S. the pDials on the body parts work, but not the BODY dials. I had this problem some months ago, it's about the Poser setting and where it's allowed to save info (externally or internally or some such). So I think I know what's causing it, but how do I fix it in this figure?
JQP posted Sun, 17 December 2006 at 2:46 PM
No, I just checked preferences and use external morph targets is off. Now I'm confused.
nruddock posted Sun, 17 December 2006 at 3:47 PM
If the loaded character isn't the first figure in the scene, then the Body dials won't be hooked up correctly.
Try loading just the character (after a restart) then INJecting the new morphs.
If the morphs now work, save to the figure library so that you can load the modified character into your scene.
pruiz posted Sun, 17 December 2006 at 6:53 PM
Is this a product (P7) or a cluster (F)?
wdupre posted Sun, 17 December 2006 at 7:04 PM
Quote - Is this a product (P7) or a cluster (F)?
It's neither, it's a known limitation of Injection technology.
JQP posted Sun, 17 December 2006 at 7:11 PM
Thanks nruddock, I did not know that.
Dizzi posted Mon, 18 December 2006 at 6:30 AM
Quote - > Quote - Is this a product (P7) or a cluster (F)?
No, it's a problem of the way the DAZ injection files are made (refering to Figure 1).
