Subject: Kirwyn's V4 Freebies
Anniebel opened this issue on Dec 18, 2006 · 10 posts
Anniebel posted Mon, 18 December 2006 at 1:03 AM
I was going to make some textures for Kirwyn freebies (camisole & pants/boots), but when I open the obj file in UVmapper it is blank. The material zones are listed, but when you select them there is nothing there.
Can anyone help - why is there no map?
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
Sheila41au posted Mon, 18 December 2006 at 1:16 AM
Hurray I can answer something :) go to map .. then planar or try the other ones ... only found this out myself cause I had an obj that did the same thing to me Sheila
Anniebel posted Mon, 18 December 2006 at 1:35 AM
So how do you know which to pick, none of them look like a real texture map?
Thanks
Helen Keller
kirwyn posted Mon, 18 December 2006 at 3:28 AM
Sorry about that Anniebel.  UV mapping is one of those things I find tedious and boring to do.  It requires alot of time to make a nice map all split up evenly with facets spread out so that a texture can be put on properly.  So I thought I could just forego this task and separate it into zones so one could just apply their textures/colors inside the material room.  Plus it helped to keep the file size down too.  I'm on dial-up and I have alot of sympathy for those in the same boat as me.  But if anyone decides they would like to UV map it and offer the new OBJ file to the community, it's quite alright with me.
sweetpegster posted Mon, 18 December 2006 at 10:27 AM
I mapped out the cami and saved the templates into two parts if You need it.
Anniebel posted Mon, 18 December 2006 at 1:35 PM
Ok kirawyn, pity though, I had some great ideas for textures.
sweetpegster - Yes please
Helen Keller
sweetpegster posted Mon, 18 December 2006 at 1:57 PM
here ya go, the new obj is in there, the name is the same, and there are two bmp's that are the templates.  peggys.fpalace.com/  .
On the side click on cami and it will download.
Anniebel posted Mon, 18 December 2006 at 2:03 PM
Thanks
Helen Keller
sweetpegster posted Mon, 18 December 2006 at 3:38 PM
I may have put the wrong obj file in there if so let me know, i dont think i saved it properly.
sweetpegster posted Mon, 18 December 2006 at 4:37 PM
Ok I have the correct files in there now, i also did the pants and boots as well. sorry for the mix up. peggys.fpalace.com/
