whoopy2k opened this issue on Dec 18, 2006 · 14 posts
whoopy2k posted Mon, 18 December 2006 at 7:10 PM
I've been away from my internet access for a week or so and missed a lot of P7 discussion. Has anyone with a pentium 4 HT tried to see if P7 will support hyperthreading?
NomiGraphics posted Mon, 18 December 2006 at 7:20 PM
Yes, Poser 7 supports up to 4 render threads at a time now. In the general preferences section.
- Noel
whoopy2k posted Mon, 18 December 2006 at 7:30 PM
So an HT thread is handled just as well as a duel core?
NomiGraphics posted Mon, 18 December 2006 at 7:48 PM
As far as I can tell it is a true hyperthreaded application now. Not just for dual core.
- Noel
whoopy2k posted Mon, 18 December 2006 at 9:53 PM
awsome... thanks for the info
timoteo1 posted Fri, 12 January 2007 at 7:07 AM
On my HT machine it uses 100% of the CPU in Task Manager (as opposed to 50% in all previous poser versions) and you see it rendering to different areas of the image at a time. HOWEVER, towards the end it drops back down to 50% for some reason and basically kills any advantage. I have timed renders with 2 and 4 threads (and also as a separate process) and the render times are IDENTICAL. :(
Actually, having in a seperate thread makes it a tad slower.
-Tim
kawecki posted Fri, 12 January 2007 at 12:30 PM
Rendering time is limited by memory access time and not by CPU, so as all cores share the same RAM it will not make a difference if you have one or 1,000 cores.
Stupidity also evolves!
Dizzi posted Fri, 12 January 2007 at 1:13 PM
Hyperthreading won't make Poser render faster. It's still just one core masquerading as two - helpful in some areas, but rendering with Poser with multiple threads isn't one. You'll need some real core for that. And don't listen to kawecki, he doesn't seem to talk from experience ;-)
kawecki posted Fri, 12 January 2007 at 1:19 PM
Quote - And don't listen to kawecki, he doesn't seem to talk from experience ;-)
And what kind of experience must I have????
Dizzi posted Fri, 12 January 2007 at 1:26 PM
Well, anyone using a multicore CPU with a multi threaded renderer will tell you that they render faster... You still claim that that's not true...
kawecki posted Fri, 12 January 2007 at 1:37 PM
Render faster compared to what?, to another computer with one core Duron?
You must compare using the same CPU, the same motherboard, the same RAM and beware of XP that can you cheat you the result.
Dizzi posted Fri, 12 January 2007 at 2:03 PM
Carrara renders the same scene twice as fast with two cores. You're now probably going to tell me that that is because one core can only access the RAM with half speed...
kawecki posted Fri, 12 January 2007 at 2:34 PM
Quote - Carrara renders the same scene twice as fast with two cores.
Have you tested it with the same computer or the renders were made on two different computers?
It will also depend on the scene content. If you have a scene where no textures are used with exception of the background, a scene with only procedural shaders, this scene will render faster with many cores.
rty posted Mon, 15 January 2007 at 11:05 AM
It's easy to benchmark.
Use your dual core computer, set up a Poser scene (any scene).
Before rendering, fire up the task manager, and set the "CPU affinity" setting of Poser to only one core (Process tab, right click on Poser). That way it only can use one core, because Windows won't give access to the other one.
Render.
Then check back the affinity for both cores, render again.
Compare times.
