Forum: Carrara
Subject: Re-orienting joints
Pinklet opened this issue on Dec 20, 2006 ยท 8 posts
Pinklet posted Wed, 20 December 2006 at 11:14 AM
I have may character, overall all the joints seem to have been rigged. The re-orient joints command seems to have guest pretty well as to how my joints need to bend. The only problem is the knees. They seem to have the wrong orientation. If I try to orient them manually my model moves with my rig, no surprise there. I can't seem too be able to detach the rig from my model. The command is always grayed out. Any suggestions?
MarkBremmer posted Wed, 20 December 2006 at 12:22 PM
Detaching bones is a little finicky in Carrara. Sometimes you have to detach in stages starting at the extremeties and working your way back. :-/ Other times, you can move down one level from the top in your character hierarchy/Parent child tree. If you post a screen shot of your set up, I can give you a little better advice. Mark
Pinklet posted Wed, 20 December 2006 at 12:49 PM
I was able to figure it out by being persistent. My model is actually very simple, it's made of 3 vertex meshes. One the body and two and three the eyes. The problem that I am still having is that some joints are not oriented properly. The command dose a decent guess, but it's only a guess, is their a way that when placing the bones, that they are oriented in a predictable fashion. I guess I will need to experiment, but my guess is it depends on what plain you place the bone, it will orient it to that plain? Mainly I will be using Axis joints and a couple of ball joints on the shoulders neck and tail. Any insight you my have will help me a bunch.
misha123 posted Wed, 20 December 2006 at 4:20 PM
Try locking the children and then rotating the joint so that the local axis (x,y, or z) is in line with orientation of the bones. Then
Pinklet posted Wed, 20 December 2006 at 4:33 PM
Sound sensible, but how do you lock the children?
misha123 posted Thu, 21 December 2006 at 12:51 PM
On Carrara 5, look for this icon. Not available for Carrara 4
misha123 posted Thu, 21 December 2006 at 12:55 PM
You may also need to turn off constraints.
Pinklet posted Fri, 22 December 2006 at 10:08 AM
misha123, Thank you very much. You provided the key to solving my problem. Not only that, but you got me curious as to what those other little icons that I had never notice before did. One turns collision direction the other disables constrains, so you don't need to do it manually just click those two icons and move the joints around. It worked very well for me. Thank you very much.
