StevieG1965 opened this issue on Dec 28, 2006 · 5 posts
StevieG1965 posted Thu, 28 December 2006 at 10:13 PM
Ok, newbie question time starts!
I have searched the manual and have looked at different sites and forums, but, can't find the answer. So I ask...
What files types can be used in V6 Pro?
And, I also say...Greetings, I'm new to Vue, I got Vue5 Easel as a gift from a secret santa this year and in less then 4 days upgraded to Vue 6 Pro. This program rocks!!
keenart posted Thu, 28 December 2006 at 11:12 PM
Steveie,
Go to this URL and you will find the comparative chart for all VUE software and the file types:
StevieG1965 posted Fri, 29 December 2006 at 7:25 AM
Ah! I missed that on the first look!
Thanks much.
Velmurugan posted Sun, 31 December 2006 at 7:18 PM
Thanks!
I have attached an image that would be a typical example of something we would like to transform into a 3D image. Vue may not be the tool for this...
keenart posted Mon, 01 January 2007 at 6:41 AM
Actually, VUE was designed to work with existing 3D objects or objects you create, although 2D images can be imported as backgrounds and Alpha planes, or projected onto objects as Maps, Bumps, and Alphas.
If you know how to use Photoshop, you can bump the images, or displace them with PSP, Painter, or, with other software, and then import them into VUE, but your results will probably not be what you are trying to achieve.
It would be much easier, to create separate 3D objects, and then compose them as one scene, which would additionally require Poser.
Software is available to convert 2D to 3D but is very expensive. There are companies on the Web that convert 2D images into 3D.
This URL might be of interest.
