rocker333 opened this issue on Dec 30, 2006 · 26 posts
rocker333 posted Sat, 30 December 2006 at 11:01 AM
-BrandyE- posted Sat, 30 December 2006 at 11:21 AM
white line is on the texture to prevent seams and it looks like the white area is a couple of pixels too large, maybe...easiest way to find out would be to throw another v4 texture on her, keeping the same pose and lights and see if it goes away...if it does, it is the texture, if not...well, then its not, lol
Brandy
rocker333 posted Sat, 30 December 2006 at 11:24 AM
Thank you for the suggestion, I will try that..............thanks! :-)
Valerian70 posted Sat, 30 December 2006 at 11:33 AM
I haven't noticed this on Pascal but I have noticed it cropping up on the Domino outfit and it shows in our render too.
rocker333 posted Sat, 30 December 2006 at 11:34 AM
I will try her with another outfit, althought right now she doesn't have a closet full of clothes............ha ha...............
-BrandyE- posted Sat, 30 December 2006 at 11:41 AM
try hiding the clothes and render then you will know
Brandy
Tyger_purr posted Sat, 30 December 2006 at 11:46 AM
looks like texture filtering.
if your in p5 or 6 turn it off in the render settings
if your in P7 you'll have to go into the material settings and turn it off (in each material zone)
i believe there is a python script around here somewhere to turn p7 texture filtering off in mass.
My Homepage - Free stuff and Galleries
rocker333 posted Sat, 30 December 2006 at 11:48 AM
So I should turn off texture filtering, I am using Poser 6...........I also will try rendering her without clothes, and see if that does it.......thanks so much for the suggestions, I appreciate it!
Tyger_purr posted Sat, 30 December 2006 at 11:55 AM
yes, try without texture filtering.
it was a common problem in P6.
I haven't seen it happen in p7's texture filtering yet but i was trying to cover all the bases
rocker333 posted Sat, 30 December 2006 at 12:08 PM
Okay, thanks for all the suggestions, I am going to try these tips and will post results when done. Appreciate you all. :-)
RAMWorks posted Sat, 30 December 2006 at 12:11 PM
Tyger, where is that script please?? Link possibly?? Thanks!!
---Wolff On The Prowl---
Tyger_purr posted Sat, 30 December 2006 at 12:43 PM
Quote - Tyger, where is that script please?? Link possibly?? Thanks!!
I haven't actually used it yet but it's made by stewer so its bound to work. :)
http://www.keindesign.de/stefan/poser/scripts/p7/turn%20off%20texture%20filtering.py
rocker333 posted Sat, 30 December 2006 at 1:38 PM
Okay, tried it with the texture filtering unchecked, still the white lines, tried different lights, etc, still the white lines.........tried a different outfit, white lines, tried it with the Poser 4 render, white lines still there but not as noticable.........sigh..........
raven posted Sat, 30 December 2006 at 2:52 PM
Have you tried increasing the texture resolution in your render settings?
Sometimes that can help.
nruddock posted Sat, 30 December 2006 at 4:17 PM
Quote - Have you tried increasing the texture resolution in your render settings?
There is no "Maximum texture size" setting in P7.
Due to the new texture paging code, this setting is no longer needed.
raven posted Sat, 30 December 2006 at 4:25 PM
I know, but they're using Poser 6 , which is why I suggested it :)
rocker333 posted Sat, 30 December 2006 at 5:04 PM
Yes, tried that too. And all suggestions are appreciated, and you all have been great to give me tips and suggestions. :-) Thanks!
odeathoflife posted Sat, 30 December 2006 at 5:06 PM
The easiest way to solve roblimatic seams such as this is to clamp the texture
In the material room there is a option under image_mapped:
off
tile
clamped
alpha
the clamped samples the colour from the edge and fills hte white.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
RAMWorks posted Sun, 31 December 2006 at 12:34 AM
KarenJ posted Sun, 31 December 2006 at 3:48 PM
No texture sold in our marketplace should have seams.
I have just downloaded this pack to check it and cannot reproduce the problem.
Can you give us a screenshot of your material settings please?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
rocker333 posted Sun, 31 December 2006 at 3:55 PM
I will, but it will have to wait until tomorrow, I work nights, and have to leave shortly.......The maker of Pascale sent me the lights she used in the promo pics, so I will try and see if that helps. :-)
blade68 posted Tue, 02 January 2007 at 1:27 AM
Pic below has my own shaders on but I have the same issue with the no shaders default mat
rocker333 posted Tue, 02 January 2007 at 1:05 PM
rocker333 posted Tue, 02 January 2007 at 1:06 PM
KarenJ posted Wed, 03 January 2007 at 4:36 PM
"you are terrifying
Shire
rocker333 posted Thu, 04 January 2007 at 10:10 AM
Oh.......duh..............I will do that today and post it.............(embarrased) hee hee...........I do know that I turned off the texture filtering, as someone earlier suggested, and still the white line............
