Subject: Areola on texture map grows with breast size
pzrite opened this issue on Dec 30, 2006 · 10 posts
pzrite posted Sat, 30 December 2006 at 6:30 PM
I haven't had much problem with this until recently, but I've noticed in several of the texture maps I've bought for V3, the areola gets huge when you increase the breast size (even just a little)
But it seems other texture maps don't do this, or it's not so much of a problem.
Other than photoshopping the texture map to make the areola smaller, is there any other solution to this problem.  (I don't like big areolas) 😊
Thanks for any advice,
Lee
pjz99 posted Sat, 30 December 2006 at 7:23 PM
areola size morph doesn't help you?
My Freebies
pakled posted Sat, 30 December 2006 at 7:44 PM
if the surface area increases, I thought the area would increase as well.
ghelmer posted Sat, 30 December 2006 at 8:27 PM
Quote - if the surface area increases, I thought the area would increase as well.
It's the same with real life boobs too...  IMHO the larger breast with smaller areola always looks like fake silicone boobs to me...  Nothing really wrong with that, but just an observation!!  LOLZ!!
G
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
pzrite posted Sat, 30 December 2006 at 8:42 PM
I had already tried the areola morph, it doesn't change the texture since the areola is also textured on top of the breast itself.
And I agree small areolas look funny on big breasts, but I also don't want them the size of a truck tire either!
I guess I'll just go back to using one of my other V3 textures.  But I was still curious as to why some textures do this and some don't.   I guess you have to start with smaller sized areolas in the texture for them not to "explode" all over the breasts!  :biggrin:
templargfx posted Sat, 30 December 2006 at 9:06 PM
if a texture map has part of the areola on the breast porton, and not textured entirely within the areola area of the model, then the size of the breast will increase the size of the areola
TemplarGFX
3D Hobbyist since 1996
I use poser native units
167 Car Materials for Poser
kuroyume0161 posted Sat, 30 December 2006 at 11:48 PM
Bing! Bing!  templargfx read my mind and wrote it in reply.  If the areola portion of the texture is not properly restrained to the areola portion of the UV map, it will stretch will the 'increase breast size' since the polygons of the breast are being expanded - without much help from twiddling nipple dials (so close to innuendo) as the already stretched portion is not affected by them.
A possible fix is to load the texture maps and UV template into Photoshop or PaintShop and do a little editing to correct this (though, I admit that the texture creators should have done this in the first place!!!).
 -- Bjarne Stroustrup
amacord posted Sun, 31 December 2006 at 3:34 AM
it's a bad thing that "texture artists" don't care about uv-templates too much - "more or less" seems to be good enough... if i'd start kicking their teeth out for each nipple, lip, eye, navel etc that does not match the uv-templates, hell, i'd need new shoes in no time!
scanmead posted Sun, 31 December 2006 at 3:53 AM
And I thought it was just me who thought this "spread" was just wrong. It seems to be more noticeable with V4. I can see why they create the textures this way: it gives a smoother transition between the breast and nipple textures. The harsher transition is a heck of a lot easier to fix, though. "Size of a truck tire" .. LOL That made my day!
Acadia posted Sun, 31 December 2006 at 4:12 AM
Quote - the areola gets huge when you increase the breast size
That's perfectly natural. If you do an internet search you will see that large breasts have a larger areola... and quite often stretch marks too :)
