SFP1 opened this issue on Jan 09, 2007 · 5 posts
SFP1 posted Tue, 09 January 2007 at 11:08 AM
Cs2 has set all my photo formats set to open inside photoshop. I want to change them back, can anyone tell me where to start?
bobbystahr posted Tue, 09 January 2007 at 12:49 PM
Open the program you wish to open the files with [in my case IrfanView] and in it's file types selecter [ in options or preferences usually ] select the ones you want to open in that program. You should get a message that these are set to CS2, say you don't wish to keep that or whatever and they should open in that app now. CS2, on install if you go automatic, will hi jack all file types it reads I've found.
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
SFP1 posted Tue, 09 January 2007 at 1:00 PM
Thanks
retrocity posted Wed, 10 January 2007 at 9:38 PM
yup, i use ivew too. i only have Photoshop open it's native PSD files, all the rest i've assigned to other apps (but most point to irfanview cause it's fast and lean)
retrocity
dreamer101 posted Wed, 10 January 2007 at 10:51 PM
Or can right click on the file and select Open With then select Choose Program. Choose the program you want to open that kind of file. Make a check in the box that says "always use the selected program to open up this kind of file" and click OK.
I have irfanview but rarely use it. I still like the old 3.1 version of ACDSee. That was the last fast loading version they made.
