ashley9803 opened this issue on Jan 09, 2007 · 12 posts
ashley9803 posted Tue, 09 January 2007 at 5:30 PM
Recently purchased Xfrog and was wondering if anyone could help.
I can export plants as .obj files but how do I texture them. The plants look great textured in Xfog but is there a way to export the textures for Poser use, or will I need to re-texture them.
If so, what would be the best way to go.
The Xfrog forum has only 2 threads, neither of which help me with this.
nruddock posted Tue, 09 January 2007 at 5:45 PM
Quote - The Xfrog forum has only 2 threads, neither of which help me with this.
The XFrog forum is very quiet, so you'll need to look in the archives for older threads.
wheatpenny posted Tue, 09 January 2007 at 6:05 PM Site Admin
A lot of Lightwave and 3dsMax, users make their trees in X-frog, so posting there might help too.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
pakled posted Tue, 09 January 2007 at 6:20 PM
2 thoughts;
UVMapper Classic (to see if you like it. If you do, it's free. Pro is spendy, but does a lot more)
Wings 3d- has a built-in Uvmapper, and allows you to do some more modeling if you like.
http:www.wings3d.com
Project Dogwaffle- a free image creation program. Supposed to be pretty good.
Project Gimp - a Photoshop clone, free and can also do stuff with texture.
http://www.gimp.org
should get you started.
ashley9803 posted Tue, 09 January 2007 at 10:24 PM
Thanks guys.
Just had a thought.
I also have ZBrush, which I think can be used to paint on textures to objects.
Don't know if I will have the same problem with texture export though. I think ZBrush exports a
material file (.mtl) which I don't know what to do with.
I have tried using UV Mapper but the result is too complex for me to texture. A tree is far more complex than a piece of clothing. Thought there might be a way to get XFrog to export an image file texture map that could be applied in Poser. I will do some more reading.
Mike K posted Tue, 09 January 2007 at 10:58 PM
Ashley, I use XFrog with Cinema4D quite often. Your plants should have a bark and leaf texture applied in XFrog. The bark texture is usually assigned to one or two materials depending on plant type and branching. The leaf texture and alpha map are assigned to the leaf material. The meshes are already UVmapped. Just manually reassign the texture maps to the materials in Poser. Be forewarned, XFrog meshes can get quite high in polygon count.
Mike K
ashley9803 posted Wed, 10 January 2007 at 2:30 AM
ashley9803 posted Wed, 10 January 2007 at 2:44 AM
rreynolds posted Wed, 10 January 2007 at 9:33 AM
XFrog's website has a poser tutorial, but I can't remember exactly where.
nruddock posted Wed, 10 January 2007 at 3:59 PM
You'll need to setup the transparency / alpha maps by hand.
Mystic-Nights posted Wed, 10 January 2007 at 5:04 PM
Attached Link: http://www.orio.ws/tutorials/xfrog3poser5/xfrog3poser5.html
Here is a tutorial on setting up in Xfrog, exporting, then bringing into Poser. You are right, you will need to create transparancy maps if the PNG has an alpha channel. This is explained also in the tutorial.ashley9803 posted Wed, 10 January 2007 at 5:48 PM
Just read that tutorial and it was good.
Have made the alpha maps which were quite easy - then I got side-tracked, always happens.
Will post a picture when I get back on task.
Thanks to you all.
